Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #13,471
How hard is it to pull to 108 Ft Lbs? That's what I need for the blade bolts on the red mower. There is another nut I can use a wrench to hold steady while pulling the torque wrench. Bolt is M14, so the socket should be 19 or 20 MM.
   / Harbor Freight Tools that don't suck #13,472
Lug nuts on a car wheel are typically in the 80 to 90 ft lbs range, so a little more than that.
   / Harbor Freight Tools that don't suck #13,473
Depends on the length of your torque wrench. 1ft long, you are pulling 108lbs. 2ft long, a much more manageable 54lb. All about leverage.
   / Harbor Freight Tools that don't suck #13,474
Depends on how much arse you have....:laughing:
   / Harbor Freight Tools that don't suck #13,475
108 is not bad, put a piece of pipe over the handle as an extension if you need it.
   / Harbor Freight Tools that don't suck #13,476
Follow up on this: The chop saw has gotten worse as I've cut more steel with it. The wobble is getting more pronounced and the saw is now starting to have trouble cutting. Motor is bogging down more easily, like it's losing power. I've made less than a dozen cuts.
I've already boxed it up and it's going back.
Now I have to decide if I'll just go with a better chop saw, maybe from Dewalt, take a chance on the HF horizontal bandsaw, or really belly up to the bar and buy something like the Makita LC1230, which is a 12" carbide blade saw that everyone raves about. Expensive, but appears to deliver.
Add $50 to it and you can get a 14" Fein. I have one, it was square right out of the box. Good German engineering.
   / Harbor Freight Tools that don't suck #13,477
I see two coupons for the click type torque wrenches, one for 9.99, the other for 11.99. Why?
They also say 'reversible' which I believe someone was asking about for left handed threads.
...How hard is it to pull to 108 Ft Lbs? That's what I need for the blade bolts on the red mower. There is another nut I can use a wrench to hold steady while pulling the torque wrench.
Same tool, $9.95 is just the best coupon price. I've had one for years and compare it against two different beam torque wrenches a couple of times per project. (It is from HF, after all) It's always right on.
I don't remember but I think it measures the same clockwise or counter-clockwise.
108 ft lbs? Just to give you an idea, near anybody could pull that using both hands. I'm getting old, pulling that with one hand might be a strain. You won't need a cheater pipe over the torque wrench, and I don't think that is recommended for a precision measuring tool.
   / Harbor Freight Tools that don't suck #13,479
My point is, I gotta do this on the underside of a 7 foot finish mower that weighs a few hundred pounds. I'll have to raise one end of it with the FEL, then rig straps to a tree to maintain support. I don't want blocks or 4x4s in the way. Then I have to hold the spindle nut with a wrench in one hand and pull or push the torque wrench on the blade retaining nut with the other.
Option is to use an electric impact wrench, but then I have no idea of the tightness rating and there's a risk of deforming the belleville washers.
Hunnert percent.
   / Harbor Freight Tools that don't suck #13,480
Hunnert percent.
Just pick it up so you can work on it?
I lift mine, every Spring, yank the old blades, pressure wash the underside, and install new blades. You can do everything standing up and your never working "under" It.
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58216)
30 INCH TOOTHLESS...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
UNUSED FUTURE MINI EXCAVATOR QUICK COUPLER (A58376)
UNUSED FUTURE MINI...
UNUSED FUTURE FT-P45 HYD BREAKER HAMMER (A58376)
UNUSED FUTURE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
