Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #13,231
Does anyone have a HF sliding compound miter saw? My old craftsman I think has given up the ghost. I don稚 use a miter saw much any more but I have a cabin to trim and don稚 want to spend a fortune on a tool I will not use often.
I bought their "best" the Hercules 12" Dual Bevel Sliding Compound Miter Saw, mostly for my wife, who is a woodworker. I've used it a good bit as well. We are both very happy with it. Lists for $350. Got it on sale for about $299 (?) There is currently a coupon for $330 in the HFQDB database.
12 in. Dual-Bevel Sliding Compound Miter Saw with Precision LED Shadow Guide
   / Harbor Freight Tools that don't suck #13,232
If you are going to spend that much, may as well go the distance and get a real one.. just my thinking..
   / Harbor Freight Tools that don't suck #13,233
I paid a bit more but not much more. The ONLY thing I don't like about it is the minuscule bat oil capacity and the filler is so small. Other than that, not bad. Comes with an Oregon chain and greaseable nose bar too. I carry a water bottle with chain oil so I can fill the tiny filler without spilling it everywhere. My wife super glues everything.
dawn bottle makes good oil bottle to fill pole saw.
   / Harbor Freight Tools that don't suck #13,234
Does anyone have a HF sliding compound miter saw? My old craftsman I think has given up the ghost. I don’t use a miter saw much any more but I have a cabin to trim and don’t want to spend a fortune on a tool I will not use often.
I have one of the Chicago electric (cheapest one) 12 in sliding saws that I have used and abused, basically using it both for framing, finish work, and a lot of laminate flooring. I cannot kill it! It is definitely out of alignment now, but good for framing / rough carpentry. I have had a couple of Makitas that I used professionally, they were good.
I now have a Rigid 12in saw which is absolutely awesome! Very precise and smooth operating. But, that is what I needed for completing our new cottage. An added advantage is the lifetime warranty on Rigid tools, but you are also paying for it with the higher price upfront.
If I needed an occasional saw, I would probably buy one of the middle or top of the line of HF saws for sure. They are decent for the price.
   / Harbor Freight Tools that don't suck #13,235
Before I buy another HF miter saw I intend to rotate the blade to check the feel of the bearings. I don't like the smoothness of the cut of the one I have now and suspect they're the cause.
   / Harbor Freight Tools that don't suck #13,236
The oil fill on my pole saw is the same as on my chainsaw, just fill it with my gallon jug.
(Looks like we’re kinda neighbors)
   / Harbor Freight Tools that don't suck #13,237
Good thought, I'll try that. The water bottle does ok but it's not ideal. No way can you fill the tiny tank from a gallon bar oil jug, just makes a mess. Both wife and I use Dawn dishwash detergent for lots if things. Dawn has to be the best degreaser ever made. Even better than ZEP) and it smells good too.
Back when I worked on heavy duty diesel trucks at the local Freightliner dealer (before I retired), we used Dawn dishwashing detergent to clean out diesel engine blocks when the head gaskets failed and let lube oil into the water jacket. Oil mixing with AF creates a gooey mess and the Dawn would clean it right out. Used it all the time. In fact Detroit Diesel recommended it. Good stuff.
   / Harbor Freight Tools that don't suck #13,239
Mine isn't (as other posters know). The oil fill on the Portland corded pole saw is about the diameter of the end of a toothpaste tube...lol and it don't hold much, maybe 1 fluid ounce at most. Very limited oil capacity.
I will say the motor seems to be powerful enough though. Powers right through limbs, no issue. Not sure the cordless ones have that much gumption but then I don't know never have had one to compare.
   / Harbor Freight Tools that don't suck #13,240
The HF battery powered one is actually very good. The motor is strong and the battery lasts longer than I do. I had an oak tree where I used it to cut 8" branches up so I'd rate it pretty high. And the oil tank apparently is bigger with a bigger cap because I can fill it from a gallon jug.
Portable Restroom (A54865)
Portable Restroom...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
40' High Cube Multi-Door Container (A53316)
40' High Cube...
PALLET OF SCAFFOLDING (APPROX. 16 PC) (A52706)
PALLET OF...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
