Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #11,681
OK. Just a few questions.
First of all, which backhoe?
Are the subframes of which you speak specific to certain backhoes or is that a universal fit type of thing?
And lastly...how does that work? Does the subframe mimic the 3 point lower arms and if so how exactly does it attach.
I have been considering adding a backhoe but I do not want to damage my tractor in any way.
The subframes are unique to the tractor/backhoe combination. All the ones I know of have 4 points of attachment. Some have all 4 points at the back of the tractor, mine has 2 points at the back and 2 points at the mid point of the tractor. On mine, the 2 points at the back slip into a slot, and the 2 at the mid point have a pin. The biggest problem is alignment of tractor with the backhoe when attaching, it has to be pretty close, i.e. within a 1/2" or less or you can't get it attached. Thus a dolly for the backhoe is very helpful.
   / Harbor Freight Tools that don't suck #11,682
The Woods 4 point quick attach subframe I mentioned earlier has all 4 points at the rear (The subframe itself stays on the tractor full-time). The bottom two are slots that it slides in to. The upper two have pins. I just drive my tractor into position, hook up the hydraulics and use the backhoe's controls to lift it into position. No dolly involved, since the backhoe is stored outside on softer ground, but I've never had a problem, and even when I'm out of practice, it doesn't take long.
   / Harbor Freight Tools that don't suck #11,683
I find the bits in the freebie screwdriver too soft but it does make an excellent file handle.
   / Harbor Freight Tools that don't suck #11,684
I got a six foot box beam level from Harbor Freight and with a 20% coupon it was about $18.00 and seems well worth it vs. say more than $40 at other places.
   / Harbor Freight Tools that don't suck #11,685
Their stocking levels are becoming a 'Do'. All too often I go for something and they don't have it. 'We'll get another truck tomorrow' doesn't help me today. And not just me. As I was wandering after hearing that, I overheard the same answer to several other queries about different items.
   / Harbor Freight Tools that don't suck #11,686
Excellent idea, I have a similar screwdriver handle that is missing the bits, that will be a excellent used for it.
Aaron Z
   / Harbor Freight Tools that don't suck #11,687
I have ti say, probably the best item I ever bought at HF is their 2500 PSI gas pressure washer. Has a Pred motor and some Chinese no name axial pump on it but, I've used it hard for 4 years now (I wash down ll my farm equipment, 2 cars and my pickup truck regularly and I've never had on issue with it. Starts first pull, uses no oil and never lets me down.
I've never even changed the spark plug. All I do is once a year, change the oil, clean the air filter and change the oil in the pump (30 weight non detergent). Thats it.
For 250 bucks (probably costs more now), it was a bargain.
   / Harbor Freight Tools that don't suck #11,688
Found that out last week myself. I wanted to buy the Zurich 200 buck code reader and it wasn't in stock and I got the same story.. Be on the truck next week.
   / Harbor Freight Tools that don't suck #11,689
It's been kind of recent too, maybe the last year or so. I don't remember it being like that before. But I'm also seeing a lot more turnover. Every time I go in, I see new faces. In the past, it was just the opposite, almost always the same faces, no matter which day of the week. I used to know some of them by name. Not any more.
   / Harbor Freight Tools that don't suck #11,690
I've heard the song about another truck coming too many times. The clerks must learn to say that as trainees.
Adams 6T (A56435)
Adams 6T (A56435)
2016 Ram 5500 Chassis 4x4 ETI ETC37IH 37ft Bucket Truck (A56858)
2016 Ram 5500...
2019 Komatsu WA470-8 Wheel Loader w/Quick Coupler, PIN# KMTWA129JJNA49506, Turbo Diesel Engine, JRB (A59076)
2019 Komatsu...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2017 MACK  CXU613T (A58214)
2017 MACK CXU613T...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
