Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #11,252
Before you cuss about HF's top hook too close to the chassis, get the Speeco extended hook to replace it. Here's a post with photos where I compared them.
This photo also shows the slide-in pins that make it simple to adjust the hook height, or even to set the hook upside down if the implement geometry is impossible to hook from below.
603428d1557086833-uses-extra-quick-hitch-top-20190125_162235rqh-speecohook4-jpg
   / Harbor Freight Tools that don't suck #11,253
Thanks for sharing that.
   / Harbor Freight Tools that don't suck #11,254
Before you cuss about HF's top hook too close to the chassis, get the Speeco extended hook to replace it. Here's a post with photos where I compared them.[snip]
I didn't realize that Speedco sold an extended top hook as a separate part. I bought a generic version to retrofit each my three HF QHs from Quality Farm Supply not too long ago when they were only about $16. They look identical to Speedco's. QFS had trouble keeping them in stock at that price, and now I see now they've bumped them up to $24.10. :)
TOP HOOK FOR CAT 1 QUICK HITCH-Quality Farm Supply
I did a quick search, and I see Speedco sells them direct for $20.
Top Hook For Cat 1 Quick Hitch
   / Harbor Freight Tools that don't suck #11,257
QFS shipping is $9.99. Do you know $$ for Speedco shipping. I checked but, couldn’t find out without creating an account.
   / Harbor Freight Tools that don't suck #11,258
With all the complaints on the upper hook problems, you have wonder why HF doesn’t just fix this??
   / Harbor Freight Tools that don't suck #11,259
What about bushings or whatever on the cat 1 implement pins?
I bought a pair of bushings but never used them as intended. In commercial daily service I suppose this would cause unacceptably fast wear but in my hobby-farm use, mowing, tilling etc for a few hours, I expect all my stuff will outlive me. I don't see any wear on the implement pins so far.
I ended up using the bushings on this trailer-ball towbar, where I needed more precise spacing to make everything snug so that added plate wouldn't bend. The bushings are welded to the little plates, and the welds help fill the slack so the towbar/plate assembly can't rotate. Both ends of each plate are bolted down to the towbar. The bushing/plate assemblies remain removable.
I've been towing a 2600 lb watering trailer for several years and everything's still snug.
475243d1469142470-pats-quick-hitch-vs-northern-kimg1766rqh-toplinkpins-jpg
Here are a couple more qhitch applications:
Carry rear ballast for using the loader in tight space.
Used the qhitch as the foundation when I built a device to lift my spike harrow using the 3-point. The cable goes over a pulley then down to the tractor, lifting the implement double the amount the 3-point raises.
   / Harbor Freight Tools that don't suck #11,260
On the HF Cat 1 quick hitch, are the lower hooks Cat 2 ...... or Cat 3 like the more expensive quick hitches??
HF used to sell a Cat 2 quick hitch but, I haven’t seen it for some time?
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2011 PETERBILT 367 (INOPERABLE) (A58214)
2011 PETERBILT 367...
2015 CAT D5K2 LGP (A55272)
2015 CAT D5K2 LGP...
1994 Stock Trailer (A57148)
1994 Stock Trailer...
2007 Oshkosh S-Series TMMB 11 Yard Front Discharge Concrete Mixer Truck w/ Tag Axle (A56858)
2007 Oshkosh...
Toro LX 425 Lawn Mower (A57453)
Toro LX 425 Lawn...
