Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #10,971
I bought 1 of the HF lites just to check it out.. I'm in the process of rigging my new shop w/ 10 lites..5000L
I ended-up building a bracket to hang it DIRECTLY over my work bench.. it works fine NOW.. I was not impressed..
After the HF shopping tour, the wife needed afew things at Walmart.. THEY have the lites at 19.00.!! I paid 25.00 at HF..
I ended-up ordering a SET of 10- 5000L off the internet.. The electrician is wiring the building tomorrow & will be hanging the NEW lites shortly.
   / Harbor Freight Tools that don't suck #10,972
If you are a Costco member get their LED shop lights when they are instant rebate price of $19.99 (fixture and two bulbs) They vary in pricing between $29 and $19 throughout the year. I now have a bunch and they have been awesome. Running the first ones for a couple + years now. No radio interference. Nice bright light (more than fluorescents) and instant on in the cold.
Do you have a part number or picture? last time I was in Costco, they had a couple of different styles.
   / Harbor Freight Tools that don't suck #10,973
The going price, full retail, on 5000 lumen, 4000k or 5000k, LED shop lights is $19 from when I've seen lately. Menards and Rural King both have them in stock and run sales or rebates getting the price down to $17 range. RK has them with blue tooth speakers built in for that price too.
   / Harbor Freight Tools that don't suck #10,974
What逞エ your thoughts on the rotary hammers?
Been wanting one for a while. Main task will be concrete drilling and driving ground rods. New harbor freight opened about 30 miles away. So far it逞エ the closest and we豎*e in the city weekly. Thinking about the 1 1/8 $97 one. There逞エ also a 1 $82 one. Next step is 1 9/16 for $150.
For those applications go 1 9/16.
Here is a link to the different bits for hammer drills.
I have the Bauer 10 amp hammer drill. I purchased it to drill holes in a 20" footing with a 3/4" bit. Drilled like it was a piece of wood. I used a Bosch drill.
I went cheap because I did not think I would ever need to drill anything bigger. Price of SDS-Max bits are higher than SDS-Plus.
I will have to get a rod driver bit for it.
My son wanted a rh for his birthday and picked out a Bosch 1 1/8, I got him a Bosch 1 9/16 SDSMAX. He used it for various projects. Last summer I borrowed it to do some concrete crack repair. It was like driving my dually for picking up groceries, for me FAR overkill. Could hardly use it one handed. Later in the summer I had a project for more repair, and part of it involved breaking concrete off about a 100' run of brick/concrete joint.
590377d1549376483-harbor-freight-tools-dont-suck-20181002_105151-jpg
The steel chisel w/ sledge was just not doing it. The HF 1/2 in. Heavy Duty Variable Speed Reversible Hammer Drill wasn't up to the task. So I got the HF 1-1/8 in. SDS Variable Speed Pro Rotary Hammer Kit, ($75 w/coupon) - that worked great.
I could easily use it one handed (it was about 4 lbs lighter than the Bosch) on the stuff I was attacking or two handed, put some of my weight on it and bust some concrete pavers.
So you can always put lighter cheaper bits in an SDS MAX or spline with an adapter. You can't make the drill more powerful. I've about 80 linear feet of concrete driveway (10' sections) that needs major repairs. I can see a 15 amp breaker hammer in my future tool buys.
   / Harbor Freight Tools that don't suck #10,975
Yup, I bought the Menard's version last summer and have two of them over my garage work bench. Work great.
   / Harbor Freight Tools that don't suck #10,976
I bought 1 of the HF lites ...
A problem with the mounting system, electrical hookup, color of light, lesser quality overall than the Walmart version, or ???
   / Harbor Freight Tools that don't suck #10,977
What’s your thoughts on the rotary hammers? FYI I bought one several years back and it "never" worked right! Would not do any hammer action, just turned out to be nothing more than a drill. Serious disappointment for me. YMMV Greg
   / Harbor Freight Tools that don't suck #10,978
I'm not completely sure on the difference between a hammer drill and a rotary hammer, duty cycle perhaps?
I've found a hammer drill pretty much indispensable if you're trying to drill into concrete.
Most hammer drills I've used you can turn the "hammer" part off and just use it as a regular drill...maybe that was your problem?
   / Harbor Freight Tools that don't suck #10,979
Some are 3 in 1
You can conventional drill
You can hammer drill which goes well with the quick change SDS bits
You can hammer alone which I say is like chipping... perfect for quickly for taking up old tile and such...
   / Harbor Freight Tools that don't suck #10,980
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
Feed Bin (A50515)
Feed Bin (A50515)
Bobcat 15 Skidloader PHD (A50774)
Bobcat 15...
2020 Kia Sportage LX SUV (A50324)
2020 Kia Sportage...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
