Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #9,151
Couple of comments, flag pole. Have had mine over a year now. I usually leave flag up, not the quickest to unclip flag. I've flown two, but usually only a 3x5 nylon. We've got a lot of wind and can be 30 mph for a week at a time. I installed near eave and put up a box made from 2x that I put a screw on front and tilt it when I take down. Helps brace pole a lot. I'd love a real pole, but can't afford right now. This one works.
Wooden bench. I've two and for the $ I can't build equivalent.
Electric pole saw works well. I've cut 6 inch diameter dried oak limbs. Not easy, but doable. One of my top 10 best.
   / Harbor Freight Tools that don't suck #9,152
Home Depot rents the Wacker model for $83/day or $332/wk.
I've got 5 little projects in mind, so renting -vs- buying would probably be a wash.
I'd come out ahead if I used it any after that, but not sure when that would be and not too excited about storing it in the garage long-term or trying to sell it on Craigslist.
90 day returns .. ;)
(joking)
   / Harbor Freight Tools that don't suck #9,153
That's exactly how I ended up with my HF 10" tile saw. I could have rented one but HD charged like $50/day. For $170 (before the 20% off) plus the cost of a blade it cost less than 4 days rental. I've done a dozen jobs with it over the last 8 years plus lent it out to friends and co-workers. I have thought about buying the compactor simply because it's a pain to rent one. By the time you add in your time to get it and then return it what could be an hour job turns into better part of a day. But, like you said, it's bulky and heavy. I've had real good luck with HF motors as long as I drain the gas out of them before storing for any length of time. As for selling it. If I came across one on Craig's list that had been used a dozen times for $200 I would jump right on it.
   / Harbor Freight Tools that don't suck #9,155
Wife actually put it together while I was at work earlier this week. I had a chance to check it out a bit last night, and it's much sturdier and stouter than I had anticipated. I guess we'll see how it holds up over time, but initial impression is very favorable.
As is my usual practice, I have been beating the [H-E-double hockey stick] out of mine, for probably either a year or 2- basically since they've been selling them, and its still just fine.:cool2:
Then again, there aren't all that many moving parts for me to screw up either...
:D
Before that, I generally used to run my miter saw on my HF welding table- which is also sturdy as all get out...- but suffered from the lack of extended support for the cut-off pieces- which I used my HF hydraulic lift table to mitigate.
:thumbsup:
Almost kind of incestuous, no?
:shocked:
   / Harbor Freight Tools that don't suck #9,156
I have the HF welding table as well. I've used it a couple of times for various things, but not at all yet for actual welding.
   / Harbor Freight Tools that don't suck #9,157
The welding table is definetly sturdy. I use mine for other things also. Trying to figure a way to rapidly mount and unmount a heavy vise when I need it. Any ideas been persued on that?
I also have the large Vulcan welding cart. Looking at installing a thick (3/8 or 1/2") steel plate to the top then have a permanent mounted vise.
Ron
   / Harbor Freight Tools that don't suck #9,159
Hand Tools at Harbor Freight Tools
Icon 1/2" drive goes from 50-250 ft lbs, 250 sounds like a lot to me. The Pittsburgh goes from 20-150, most of my tractor bolts are around 100 lbs, most wheels are 75-125 lbs. Makes me wonder what takes over 150 ft lbs?
My HF torque wrench is dial adjustable and can be used for a ratchet handle for 3/4 inch sockets. It goes up to 600 lb-feet. My 19.5 inch Alcoa aluminum wheels on my DRW Dodge Diesel Ram 3500 4x4 takes 450 lb-ft of torque on the lugs. Lots of garages can't get there with their air tools so I carry it in the service body cabinet in case it is needed. It is a big sucker. I named it Excaliber!
Patrick
   / Harbor Freight Tools that don't suck #9,160
Patrick
Was gonna say, the RV wheels are @ 450lbs.
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
McFarlane 4025 Reel Disk (A59814)
McFarlane 4025...
2022 ALLMAND LIGHT TOWER (A58216)
2022 ALLMAND LIGHT...
Giyi Mini Pallet Forks (A57149)
Giyi Mini Pallet...
SD Lanch SDLGC80 Electric Golf Cart (A57149)
SD Lanch SDLGC80...
