Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #9,041
If it hasn't been mentioned the yellow steel sawhorses work great. Buy them one at a time with a coupon. I use some twist ties to keep the leg support from flopping around when I store mine.
   / Harbor Freight Tools that don't suck #9,042
I'd appreciate any thoughts or opinions on these two rotary hammers to drill 5/8" holes in granite about 4" deep? Currently $70 vs. $150. I already have an electric demo hammer.
   / Harbor Freight Tools that don't suck #9,043
I have a pair that came together w/o the telescoping legs from, I believe, Menards for the same price on sale.
   / Harbor Freight Tools that don't suck #9,044
I have the 10 amp model. Only used it in concrete. Drilled 2 holes 5/8" diameter 36" deep recently in cement block. Had no problems. It is heavy to hold in a horizontal position. I used Bosch drills in it.
   / Harbor Freight Tools that don't suck #9,045
I don't even know when the compressor is running. Before, I have a Craftsman 40 gallon POS compressor in the upper bays, that thing was unbearable loud! I hated it.
I have the same compressor and one needs ear plugs when it runs in the same room with you.
I moved it thru the wall and into my boat shed but is was still pretty loud.
I saw an ad for a Kobalt compressor at Lowes as being the quietest compressor on the market so I bought one. It only has about 6CFM at 90 PSI but man is it quiet. I doubled it up with my Puma compressor (6.5 CFM) (somewhat loud but not as much as the Craftsman) for those times when I need a bit more volume. So far I have totally quit using the Craftsman which was basically just using the tank for volume storage anyway.
As a side issue, anyone have a fix for a leaking pressure regulator on the Craftsman. I have replaced it multiple times with a non OEM regulator and the same thing happens. It cuts on and off ok but a relief valve? on the regulator pops off and doesn't close till it is down to 90 PSI at which time the compressor kick on again and just keeps cycling that way. I have tried adjusting the relief valve but with no luck. I wont spend $150+ for a Sear regulator for it which is why I now have a Puma and a Kobalt small piggy back double tank compressors.
   / Harbor Freight Tools that don't suck #9,046
I have decided to get a sun canopy for my new tractor. I'm going to need to get rid of some low branches in my fields. The ROPS didn't mind them but don't want to ruin my canopy.
Anyone have experience with this? Thinking electric might be cheaper and I won't care if I have to stop and recharge. Not really any hurry.
9.5 In. 7 Amp Electric Pole Saw
   / Harbor Freight Tools that don't suck #9,049
Funny, just realized that. Battery is about 2x cost. I don't have a generator so will need to be battery. Any body have any experience with this one?
4V Lithium Cordless Pole Saw
I have the Lynxx pole saw, it's an amazing saw for the money. The battery will far outlast you. I love it!
   / Harbor Freight Tools that don't suck #9,050
I have it and its awesome for the price. I put a portable generator in my FEL bucket and go where I want.
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2013 Felling Trailers 8 Ton T/A Side Dump Flatbed Trailer (A56858)
2013 Felling...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
