Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #8,461
Thanks Reb. I think I need one in the 15-25 watt range, but an all in one.
Sunforce has been around a while, not sure if they are any better. So many of these solar builders come and go...
   / Harbor Freight Tools that don't suck #8,462
Haven't been on here in a while, would appreciate some recommendations from you HF experts.
I have a fairly small UTV battery powering a new DC fence charger. I would like to put a small solar charger on the battery
to extend the life of the charge.
Do you have any recommendations for HF solar chargers that work? Under a hundred bucks for sure.
I know there are varying grades of panel construction, different chemistries.
I see the ones in Northern Tools which frankly I would tend to trust more than HF. But maybe they are buying the same unit from China
and putting their label and paint job on it. Have seen that a bunch of times. Or maybe it's the knockoffs knocking off the knockoffs...
thanks Drew
Drew, I built one that I think is what you'd like, quite inexpensively from some Amazon parts - a universal battery, a decent solar panel, a cheap charge controller and a nice sealed box. Maybe $60-$75 in the whole thing. I use mine to power a driveway alarm. You can select whatever size/capacity suits your need. Mine is 5w/8aH, mainly because that was the biggest battery that would fit in the box, and the panel was a nice size to mount on the box. It's been working perfectly for over 3 years now. I was quite surprised to find that almost no one is making "pre-assembled" little solar charging setups like this.
Amazon.com : Solar Panel 5 Watt 12V Poly Crystalline-Grade A Cells-Diode-5W Panels : Garden & Outdoor
Amazon.com: docooler 1A 12V/24V Solar Charge Controller Solar Panel Battery Regulator Safe Protection: Garden & Outdoor
Amazon.com: UPG UB128I Sealed Lead Acid Batteries: Home Audio & Theater
Amazon.com: ESPi EC-1 Outdoor Enclosure Outdoor PVC Enclosure, 8" W x 4" H: Home Audio & Theater
It looks like some of this stuff is rising in price and becoming less available. I wonder why?
   / Harbor Freight Tools that don't suck #8,463
I have a bunch of Irwin screwdrivers that look just like that... wonder why?��
In it's earliest days, HF seemed to sell lots of products from lots of places and I think they still do except now they may be HF branded.
   / Harbor Freight Tools that don't suck #8,464
I bought a 15kw generator from them, surprised that it said "made in Milwaukee" on the box. Generac brand.
   / Harbor Freight Tools that don't suck #8,465
I bought loads of U S General tools from them in the olden days along with one of the first Makita 7.2 V drills. The Chinese connection was always there but not to the degree of the past 10 years. They used to sell lots of Japanese things way back then.
   / Harbor Freight Tools that don't suck #8,466
Sixdogs, the Costco tarps are probably 3 times the thickness of anything from HF. And have UV stabilizers too, I believe.
Indeed they are. We were in Costco and I felt one of their blue tarps and it seemed way thicker than a HF tarp. In fact, the HF tarp felt puny by comparison.
   / Harbor Freight Tools that don't suck #8,467
I think HF started out, back in the mimeographed letter days, selling odd lots of whatever they found at odd places like Customs auctions. "Harbor Freight & Salvage".
image.php
Copyright info for the logo above
Classification Information
International Class
008 - Hand tools and implements (hand-operated); cutlery; side arms; razors.
First Use In Commerce Date
1988-02-00
Another
HARBOR FREIGHT SALVAGE CO. Trademark Information
Central Purchasing, Inc.
CLOTHING, NAMELY, SHIRT AND CAPS
July 25, 1988, a U.S. federal trademark registration was filed for HARBOR FREIGHT SALVAGE CO. by Central Purchasing, Inc., CAMARILLO, CA 93011
[abandoned 1996]
   / Harbor Freight Tools that don't suck #8,468
HF was in biz in at least the late 1970's. Those must be later things as the biz grew.
Really, it's an American success story.
   / Harbor Freight Tools that don't suck #8,469
thanks, nice set up. The charge controller isn't waterproof for sure, so it needs a watertight compartment.
I did find a few combo kits on Amazon. I really need to study the specs on the electric fence and find out what its daily
consumption will be, and then can size this sensibly without guessing.
Amazon.com : 35 Watt Solar Panel Kit, Build Your Solar Charger In One Stop (1A 35W Kit) : Garden & Outdoor
   / Harbor Freight Tools that don't suck #8,470
I would avoid the $15 HF one. I picked one up to use on an ATV that isn't used much. When I needed it, battery dead. Checked the output of the panel, just a fraction of a volt. Took it apart, and found a bad connection between one wire and the panel. It was held in place with some sort of goo...neither the cheap Chinese wire nor the panel itself would accept solder.
Finally used real wire and epoxy to hold it in place. Works, but I don't really trust it.
I haven't tried any of their other panels.
Toro Reelmaster 3100D Reel Mower (A50121)
Toro Reelmaster...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
John Deere (A50322)
John Deere (A50322)
2019 John Deere TX Gator Utility Cart (A50322)
2019 John Deere TX...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A52141)
2012...
