Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #7,781
I have used these "piano movers" many times to..... move pianos! Weighing maybe 600-800lbs. It is prudent to occasionally lube the wheels and the caster swivels and check the hold-down nuts. After bouncing in a trailer for a few hundred miles once, I found about half the nuts on the trailer floor.
   / Harbor Freight Tools that don't suck #7,782
The wood dollies are ideal for moving furniture and other cases where it won't stay loaded long enough (months) to get flat spots on the wheels.
I just noticed one of the nuts holding a caster has disappeared off one of mine. At HF final QC is left to the customer. Don't take uniform quality for granted, inspect when new and after a while.
<snip>
I must push mine around enough in my various ramblings around the shops because I have not noticed any bad flat spots yet.
   / Harbor Freight Tools that don't suck #7,783
What's this? On the HF website 'Vulcan' returns only welding consumables, gloves, and this welding cart.
Looks like they will soon have a new line of (more expensive?) welders. Searching 'Vulcan Welder' returns a manufacturer in India.
I bought one of those carts when they had the 25% off at July 4th. It is a very nice unit, heavy, drawers roll nice. I am thinking of putting a steel top on it for a welding table. I use it for my O/A tanks and stuff. I have one of the smaller ones to put my arc welder on. It is equally nice. waiting to see reviews on the new Vulcan line of welders.
Ron
   / Harbor Freight Tools that don't suck #7,784
Ron
Cart mentioned is too light for a welding table. I made one out of square stock with a wood top and put a piece of 1/4" plate on top. That's my welding table that, if I ever wanted, could be a HD rolling bench in a few seconds.
   / Harbor Freight Tools that don't suck #7,785
N
How difficult is that to swap out?
Not difficult at all, really. A few mods were needed.
I had to make a motor mount because the plane of the pulley was different on the replacement. A couple of pieces of perforated square tubing allowed me to move the motor where I needed it. Then I had to measure the belts, and order something to fit. The new compressor had a double groove instead of a single like the old one. I could have run with one belt, but I decided to go with the double, so that needed a new pulley for the motor. But then, I needed a new one anyway because the diameter of the new compressor pulley was different. I looked up a pulley ratio calculator online to determine the new motor pulley size to keep the pump RPM where it should be.
That was the most complicated part. Then I had to craft some custom plumbing because the old compressor had a half inch outlet, and the new one is 3/4". Not a big deal. I took the opportunity to put a new pressure switch on it, too. Didn't trust the old one, but at the moment I don't remember why.
So, it sure wasn't plug and play but nothing to be afraid of. Any handy man should be able to do it with no problem. :drink:
   / Harbor Freight Tools that don't suck #7,786
Are the furniture Dolly's you can get for like $8 worth it? I want to build wheeled platforms for my sprayer (60 lbs) bush hog (500 lbs) and tiller (650 lbs).
For the sprayer I just need one. For the hog and tiller I need 2 each for sure. May need 4 just to have wheels in all the right places. Thinking of cutting them up to get the wheels and build my own platforms out of scrap pallets and dimensional lumber I have.
They sell loose casters as well.
Rigid Casters & Rigid Caster Wheels
Harbor Freight Tools – Quality Tools at Discount Prices Since 1977
We use the small dollies to put implements like pallet forks, wood chipper etc. to roll around the garage. We use two for the 450 lb wood chipper, no problem.
Have two of the "big wheel" hand trucks and find them invaluable. 7 lb. Capacity Bigfoot Hand Truck
   / Harbor Freight Tools that don't suck #7,787
I found it interesting to compare the "250# rated" loose wheels to the wheels on the "1000# rated" cart. The loose wheels are significantly larger and heavier than the ones on the cart which are supposedly rated for the same weight.
Aaron Z
   / Harbor Freight Tools that don't suck #7,788
I have a few of them and all get used consistently with no damage or problems so far. I set a chunk of 4x4 on one, then set the front of my rotary cutter down over it. That and the tail wheel allows one handed moving of the cutter on a concrete floor.
   / Harbor Freight Tools that don't suck #7,789
I have that hand truck. Its excellent to use however the tires don't hold air between my infrequent uses of it. If the air loss isn't in the tread area I doubt Slime in the tires would help. (HF seems to sell a lot of Slime, I wonder why? :) )
I've thought about welding up a frame I can mount on that hand truck to make it a trailer for towing my harvest ladders down into the orchard. If I'm not towing the 4x8 trailer then I carry the 8 and 11 ft ladders crosswise above the front loader and zig-zag around dodging tree props. Towing these and longer ladders behind me lengthwise would work better. Another project for when I get around to it. Has anyone done this?
   / Harbor Freight Tools that don't suck #7,790
I've thought about welding up a frame I can mount on that hand truck to make it a trailer for towing my harvest ladders down into the orchard. If I'm not towing the 4x8 trailer then I carry the 8 and 11 ft ladders crosswise above the front loader and zig-zag around dodging tree props. Towing these and longer ladders behind me lengthwise would would work better. Another project for when I get around to it. Has anyone done this?
I would suggest using a 3 point trailer mover for the front, make a swivel bracket that connects to the top of it and connect the top of the ladder to that. Then strap the bottom of the ladder to the hand truck. When not moving ladders, hook the hand truck to the trailer mover bracket so it hangs off of the ground.
Aaron Z
2001 Freightliner MB55 Bus (A56858)
2001 Freightliner...
12FT X 20FT LIVESTOCK METAL SHED (A58216)
12FT X 20FT...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56436)
Adams Load Out...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58216)
1982 SHOP BUILT...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
2007 NEW HOLLAND B95 BACKHOE (A52709)
2007 NEW HOLLAND...
