Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #7,421
What thickness mild steel do you limit it to?
Mark, depends on how much time you have or how nice a hole you need/want. I use them in the drill press all the time. Awhile back I stacked 4 pieces of 3/8 flat bar parts I wanted matched up and it took about 30 minutes. Use plenty of that sulfur based cutting oil. You can stack and drill the pilot holes with a long bit, then un-stack. Most of mine are the deep ones. Be sure and put a piece of wood in the vise though.
I haven't been on this thread for a time. Did not know you were a regular. Maybe now I will have time to read all this esoteric stuff and watch your smoke.
Ron
   / Harbor Freight Tools that don't suck #7,422
Does HF have a decent drill press that will drill up to half inch steel ? Decent price? Garage use at home, not for a buisness.Thanks.
I have one of their older 16 speed bench mount. Drill 1" holes with it a lot (lowest speed) and good sulfur cutting oil. Have used 6" hole saws in it also (slow process)
Ron
   / Harbor Freight Tools that don't suck #7,423
I have one of their new floor standing 16 spd drill presses. It replaces the same older unit I sold when we moved up here. I too only use it occasionally in my home shop, and it does good for that. It will drill 1/2 mild steel just fine as long as you use a slow speed setting, lots of cutting oil and a slow feed speed.
If I was a production shop that needed a heavy duty drill press for constant production use, I would look elsewhere.
   / Harbor Freight Tools that don't suck #7,424
Just got a new catalog/flyer in the mail and they have a new roller cabinet with wood top, Yukon brand. Looks nice and only $289. Anyone seen one in the store? I have a a 25% coupon for Monday.... Might have to check it out.
   / Harbor Freight Tools that don't suck #7,427
I've been in need of a GOOD drill press and looking for years. Amazon and WalMart had been running a price war on Wen tools, cheap knockoffs similar to HF.
Well they had the WEN 8" 5-Speed Drill Press on sale for $35 a couple of weeks ago. Now it's back to $75 at Walmart and $82 at Home Depot. So I decided for $35 I could get that and wait on finding a GOOD drill press. It's got a bunch of reviews on Youtube.
They might start the pricewar again.
   / Harbor Freight Tools that don't suck #7,428
If that doesn't have more power than the HF $39 benchtop drill press I bought several years age - don't bother. Not only weak, but impossible to tighten the chuck sufficiently. That wasn't really a general shop tool. It was more like a specialty tool for an electronics lab or something that wouldn't need much force. I hope HF's current model is better.
   / Harbor Freight Tools that don't suck #7,429
Hmm.. About 7-8yrs ago I bought a 'managers special' at TSC of a 12" table top drill press and 6" bench grinder combo for $50. Both have been doing pretty good so far. I image the HF ones have caught up in quality since then... maybe.
   / Harbor Freight Tools that don't suck #7,430
HF typically excludes cabinets, tool boxes, etc. from Coupons.
2014 Freightliner 105' Bucket Truck (A56436)
2014 Freightliner...
2021 Bobcat T66 Skid Steer (A57453)
2021 Bobcat T66...
JRB Quick Attach 8' Loader Rake (A57148)
JRB Quick Attach...
2016 Ford F-250 Knapheide Service Truck (A56858)
2016 Ford F-250...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
