Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #5,681
Yep, the gray one. I just wish they were about 12" taller. As I previously posted, I plan to build up a base, to raise the press, with some 6-8" casters to make it more mobile.
My plates are steel.
I put mine on 3in casters... agreed could even be a little higher. I'm 6'2". I've been paranoid about my plates that came with it hearing horror stories. So far no failures but I haven't pushed it. SWAG has some apparently great plates but hard to justify the expense. Arbor plates $162.95... 20T press $159. Go figure. I did modify the press swapping out for a HF pneumatic jack and that is a dream compared to the hand jacking method.
   / Harbor Freight Tools that don't suck #5,682
HF has a fantastic profit margin anyway. All Chinese sweatshop products with an over-the-top markup. I get a charge out of the rice paper cardboard boxes their stuff comes in.....
   / Harbor Freight Tools that don't suck #5,683
DE, I wonder if HF would sell some of the new steel plates?
Here's some for $60 on eBay.
2 Ton Steel Shop Press Bed Plates H Frame Arbor 4 Notch 5"x 5" Set | eBay
   / Harbor Freight Tools that don't suck #5,684
DE, I wonder if HF would sell some of the new steel plates? Here's some for $60 on eBay.
I don't know how good the eBay version would be. Swag sells high strength steel plates for the HF 20 ton press but they cost over $150 a pair.
   / Harbor Freight Tools that don't suck #5,685
I just sent a message to eBay seller to see what steel he uses. At least they're made in USA?
The HF steel arbor plates still come from China so, how do we know what they are?
SWAG has good products but, not sure they are from $60 to $160 better?
   / Harbor Freight Tools that don't suck #5,686
If you look at the dimensions of the $60-100 eBay plates you will see that they are considerably smaller in both size and thickness than the ?8x10x1.5 SWAG version. They are also probably mild steel compared to high strength steel from SWAG. I'm not sure that everyone really needs the full blown SWAG version but I do think they are bigger, beefier etc. SWAG makes only good stuff and prices it accordingly.
   / Harbor Freight Tools that don't suck #5,689
hate to act dense but what is SWAG?
Swagoffroad.com manufactures "upgrades" for several HF metal working tools. Allows crappy HF tools to produce precision bends Etc.
I think they got started selling Jeep customizing items but a lot of their business now is tooling. They also make the bandsaw benches we've been discussing.
   / Harbor Freight Tools that don't suck #5,690
I looked at the plates, I referenced on eBay, as a suitable replacement for the cast iron arbor plates that came with the older 20 ton presses.
The ones, from SWAG, are indeed larger and for higher than 20 ton capacity presses so, not really germane to the conversation about the cast HF plates.
Kinda like putting load range E tires on a 1000 lb. HF trailer?
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
43055 (A55851)
43055 (A55851)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Hydraulic Tree Sheers (A55272)
Hydraulic Tree...
1979 John Deere 4430 Farm Tractor (A57453)
1979 John Deere...
