Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #9,391
There is another thread that is specifically for HF tools that AREN'T worth buying.
This the one we [mostly] use for ones that are [mostly] fit for use, or to explain what applications they are/could be useful for, in addition to what they aren't.
So if you had said, 'this rubber-headed mallet might be useful as a stick, and maybe a light paperweight, but don't have your SWMBO try to pound on anything with it....', that would've fit the thread parameters a mite better.
Just sayin'
another thought- or for saying- this tool sucks as sold, but if you ......... **insert modifications to make cruddy import tool useful** that would've been more in keeping with the general idear...
This thread long ago became the default thread for suck and don't suck. I've read every post for over 10 years and the two different threads were cumbersome and confusing. A good tool to one may not be to others plus there are varying degrees of happiness or unhappiness with a tool. It's all very subjective and when you factor in hut or miss issues, one thread rose to the top.
   / Harbor Freight Tools that don't suck #9,392
These small handle side cutters, or whatever they're called, are the best I've ever owned. They're from HF and are 25-ish years old. Look at the edges and uniformity in the photos below. Real quality.
View attachment 563976 View attachment 563977
I bought them after I bought a high priced pair of USA made clippers and the jaws were not even. Junk. Since then, I've bought other high dollar USA made clippers and been disappointed in one way or another The HF ones cut small wire clean and even. No, no one can borrow them.
This fell apart after my wife swung it 5 times. I think she is putting the kibosh on any more HF purchases.
I think what you purchased is a "hammer kit". Comes with handle and rubber head. Assemble with proper glue and fasteners before using. :laughing:
   / Harbor Freight Tools that don't suck #9,394
Just for the record...The first time I read the thread title I thought it was a gag post...!
BTW...I was a lurker for almost three years before I registered...
   / Harbor Freight Tools that don't suck #9,395
Linky's no worky.
   / Harbor Freight Tools that don't suck #9,396
Do any of you have any experience that says to not buy their Zurich OBD2 scanners? The second one down in the line does engine, SRS and ABS. And it's on coupon for about $120.
   / Harbor Freight Tools that don't suck #9,397
The Zurich scanner I'm referring to is the ZR11 that has a $119.99 coupon.
For $120 I'm thinking that it may be a great buy. I have been Torque Pro on Android for a long time, but it doesn't get in to the ABS system.
What I want to do is be able to drill down to what specific of the four wheel bearings or speed sensors is causing my fault rather than changing out $160 bearings and $40 sensors until I get lucky.
Description
The ZR11 OBD2 Code Reader by Zurich is ideal for master technicians who work on domestic, European and Asian cars. The ZR11 diagnoses and erases ABS codes and lights, can graph and record live data, and has a battery reset feature. It includes an OBD connector with an LED light for easier access to the under-dash port and battery so you can move around the vehicle and shop. Features bilingual display in English or Spanish and has a patented 2.8 in. color screen that displays 20 data points at once.
Works with virtually all cars, light trucks, minivans, SUVs or hybrids manufactured since 1996 (OBD2) – foreign and domestic
Patented 2.8 in. all-in-one color display shows 20 data points at a time, including Diagnostic Trouble Codes (DTC) and their definitions
Freeze frame shows engine condition at time the Malfunction Indicator Light (MIL) was triggered
Test battery/charger/alternator for cars that have difficulty starting
Diagnose and reset anti-lock brake (ABS) codes
Record, graph and play back live data onscreen
Reads Engine Control Unit (ECU) information
Multilingual display - English, Spanish
Color-coded LEDs give at-a-glance indication of test readiness and vehicle condition
The software update with instructions is available for download under the Software Update tab above. Coverage for new model vehicles may be limited and will be available once released by the automaker. Availability is typically 12 to 24 months after the release of the model year. Software update now available for 2017 coverage.
   / Harbor Freight Tools that don't suck #9,398
Who said average anyway?
Title is "....Don't Suck"
Which has a pretty nonspecific definition but prolly means something that is or can be useful.
Oh, and BTW, sorry to act like thread police- when I'm really just me- that's why I revised my post several times before moving on- I didn't want to seem or come across as harsh or thinking I'm better than the OP...
If you're going to get real **** about it, probably everything but their vacuums!
   / Harbor Freight Tools that don't suck #9,399
Buy the better, non-HF, ty-wraps that are UV resistant. It痴 not the color, it痴 the material.
I bought a package of white and black tie wraps at HF when on sale a year or two ago. The black ones would break just lightly tightening but the white ones work as they should. The bad ones would break at random locations like a piece of flat candy.
   / Harbor Freight Tools that don't suck #9,400
I've had two for several years, with no problems I use one to reseat hubcaps without marring the metal, and they're great for that. I use another to seat snug-fitting horse hoof boots. So YMMV. :)
2001 GMC C7500 Tree Truck (A55272)
2001 GMC C7500...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
24in excavator tooth bucket (A56436)
24in excavator...
2347 (A58376)
2347 (A58376)
2284 (A58376)
2284 (A58376)
Behringer 19 high x 43 wide Metal-Cutting Bandsaw (A59213)
Behringer 19 high...
