Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #8,041
I recently needed to cut a slit in a pipe.
Tried many different ways & couldn't get a straight cut lengthwise.
Bought this (7-1/4 in. 48T Metal Cutting Circular Saw Blade) metal cutting blade for my skill saw & IT WORKED!!!!!!. (mounted in my radial arm saw.)
I don't know how long it's going to last but it sure beats a hacksaw or even a sawsall.
   / Harbor Freight Tools that don't suck #8,042
A few days ago I posted about buying this kit - Air Compressor Pressure Switch, Safety Valve, and Gauge - $12.50 on Ebay.
1/4" BSP 4 Port Single Phase Air Compressor Pressure Switch + Safety Valve Gauge | eBay
...To repair my year 2010 Harbor Freight 10 gallon compressor.
attachment.php
I got the kit installed.
Thank you for the comprehensive notes- they may be helpful for many of us at some point.
PA
   / Harbor Freight Tools that don't suck #8,043
Handy, yes but if you keep in the barn, put in a plastic bag. The mice LOVE them.
Plastic bags don't stop the destructive behavior of the members of genus rodentia in our barns or out buildings- in fact very little except frequent presence of humans or some of our 4-legged assistants [particularly the feline one] keeps them suppressed.
For that reason we have rodent traps spaced throughout the perimeter of the barn, including one at each end of the roll-up door.
Unfortunately, HF doesn't sell any traps apropos for the smaller rodents we see, only these: Search results for: 'trap'
   / Harbor Freight Tools that don't suck #8,044
Is that the usual diameter blade that your Radial Arm saw uses?
Mine is [IIRC] 10", [at least] and I don't recall ever having seen any smaller bladed ones.
Mine's an old Sears-Craftsman I "inherited" from a B-I-L, what make is yours?
I'm asking because if the 7.25" diameter blade worked on yours, I could prolly use it on mine too, and that would be a great addition to my cold-cut cut-off saw, which I can't use to make long straight "ripping" cuts on linear stock any better than you could.
   / Harbor Freight Tools that don't suck #8,046
...Radial Arm saw... 10" ... old Sears-Craftsman ...
Are you familiar with the recall on some of those saws? Send in the motor, get $100. I did this with the one I inherited. There was a design error that would let the work jump upward into the unshielded blade.
Craftsman Radial Arm Saw Recall
   / Harbor Freight Tools that don't suck #8,047
Nope, probably because I was gifted it by my B-I-L after he legitimately inherited it from his dad and, had already bought a better newer one...
But many thanks, now that I know, I'll look into it post-haste!
Did you replace the motor with some fraction of the $100, because I don't think I can buy a comparable radial arm saw for that price.
PA
   / Harbor Freight Tools that don't suck #8,048
Here's one that does suck, their 1.5W solar battery charger. I picked one up to use on an ATV that's normally stored in a shed with no electricity. Last time I tried to start it, battery dead. Put a meter on the panel connector, 0 volts. Took it apart, everything looked connected, but the wires are just held to the back of the panel by some sort of snot, which apparently wasn't doing a very good job making contact. Tried to solder them on, but neither the panel nor the cheap Chinese wire they used would accept solder. Finally glued them on with some epoxy. Works now, but even in direct sunlight barely puts out 12V. At least I got it with a 20% off coupon. :confused3:
Curiously, how is the output wiring attached on "real" solar panels?
   / Harbor Freight Tools that don't suck #8,049
Something I just ran across is a fuel injection replacement for the carb on Predator 212 cc engines...
For those that are not familiar with the 212...they are a Honda clone and most honda and 3rd party performance parts will fit the 212...
here's a link to the mechanical injection Tillotson TCT Mechanical Fuel Injection ( Carburetor Replacement) - GoPowerSports.com
Hi /Pine,
Have you tried using one of these yet?
I have a 420cc Predator motor on my DR Brush Mower, and it's a great running engine, once it gets started, but despite using fuel stabilizers, and running it dry in the fall, it seems like every spring I still need to take the carb off and apart and clean and degum it- and even though I've gotten pretty practiced at it after several seasons, it's a true PITA, and inevitably, I foul [euphemism for what comes out of my mouth loudly at this juncture yearly] something up and have to replace or repair some ting.
So, if this was a likely more reliable way for fuel/air to get inside it, I'd love to get one...
Thanks,
PA
   / Harbor Freight Tools that don't suck #8,050
We’ve had really good luck with these to catch mice in and around feed room at the barn and in the shop.
I buy them at Wally World and Home Depot.
https://www.walmart.com/ip/Victor-Easy-Set-Mouse-Traps-4-pk/12166945
Sheets of Tin (A57149)
Mini Plate (A57149)
Mini Plate (A57149)
2007 Oshkosh S-Series TMMB 11 Yard Front Discharge Concrete Mixer Truck w/ Tag Axle (A56858)
2007 Oshkosh...
2022 Ford Explorer 4WD SUV (A56859)
2022 Ford Explorer...
2010 Volvo XC90 SUV (A56859)
2010 Volvo XC90...
T/A Utility Trailer (A56859)
T/A Utility...
