Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #12,843
When I was very young Mom put freshly picked gooseberries in the dryer to de-stem them, remember eating lots of gooseberry jam!
   / Harbor Freight Tools that don't suck #12,844
Yeah. That was an experiment that turned out to be a waste of time.
Nonsense. Edison failed nearly 100 times before he perfected the light bulb.
Failures are not wastes of time if you learn from them.
   / Harbor Freight Tools that don't suck #12,846
Another kind of tumbler - I bought HF's smaller cement mixer hoping to knock the hulls off of walnuts. Since the final output is food I used bolts for the abrasive, to not leave any residue.
Nothing I tried worked. :mad:
I sold the mixer.
What size bolts did you use?
I use rocks about softball size or bigger.
5 gallon of black walnuts, half gallon ~ of water, 6 rocks and let it spin maybe 15 minutes.
   / Harbor Freight Tools that don't suck #12,847
I didn't use anything that large, maybe half inch by 6 inch bolts up to a little larger. The hulls were like sponges in absorbing abrasion. An hour run didn't do much.
I don't have the climate to effectively dry them in the sun before tumbling. Often fog or at least wet grass until 11am. I'm a few miles inland from the ocean. I don't think they were dry enough.
That was the second year, the first year I stripped them by hand scraping on expanded metal mesh and that was more productive than tumbling them. After this I haven't tried anything else, there's too much going on in the summer to put time into this project. Now the walnuts are left for the squirrels.
..............That was the second year, the first year I stripped them by hand scraping on expanded metal mesh and that was more productive than tumbling them. After this I haven't tried anything else, there's too much going on in the summer to put time into this project. Now the walnuts are left for the squirrels.
For two years in a row, we've used a pressure washer to take off the hulls. Use a milk crate to hold them while blasting. Then put them in the attic to dry out.
   / Harbor Freight Tools that don't suck #12,849
My BIL uses the corncob media, and I know about the ultrasonic.
But by far the best method for cleaning brass is a tumbler with stainless steel media.
Often the brass comes out of the tumbler cleaner than out of the box ammo.
Yeah, but then like with the ultrasonic you have to dry it... its ammo, not jewelry
   / Harbor Freight Tools that don't suck #12,850
I already have the leveler. What I'm looking to do it modify the legs so I can lift heavy (up to 1000lbs) woodworking equipment.
That's what your FEL is for..
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A56435)
2023 Kubota...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A56857)
2015 Vermeer SC362...
