John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,667
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
I've burned up two of the $9.95 angle grinders. Their proper application is a wire brush wheel or similar that doesn't need huge torque and won't be run continuous. They are fine for that.
First one the plastic fan disintegrated after 20(?) years of infrequent use cleaning welds with a wire brush wheel. It still ran but I gave it away.
Second one I mounted in the 'cutoff saw mount' from Northern Tool that I described in this recent post:
https://www.tractorbynet.com/forums...-freight-tools-dont-suck-528.html#post5287449
That worked well until it didn't. A couple of minutes running continuous slicing a 7/8" bolt and it faded away, smoking, just as it finished the cut.
I like that cutoff saw mount but I'm a little leery of putting a more expensive grinder in it. I think it needs a very light touch feeding the grinder into the cut.
I ordered one of those cut off saw mounts recently. It seems like a great setup, but unfortunately, it won't work with my ancient HF grinder. When I mount the grinder in the cutoff, part of the mount depresses the shaft lock (the one you use to hold the shaft when swapping out a grinding wheel), so the wheel will not turn when the grinder is in the mount.
