Harbor Freight tools that DO suck
Status
Not open for further replies.
   / Harbor Freight tools that DO suck #241
i also have the blue plastic and steel ones, those seem pretty good.
   / Harbor Freight tools that DO suck #242
The key with those is to get the weight evenly distributed across the whole dolly and not have any point loads.
Aaron Z
   / Harbor Freight tools that DO suck #243
I have my HF welder (Mig-180, $25 used) on the small wood dolly. Getting the stinger cable that close to the floor gives fewer bends compared to tabletop so it feeds more smoothly. Recommended!
   / Harbor Freight tools that DO suck #244
The weight needs to be evenly distributed across the carpeted sections and on top of the casters. The crossbars between are just that, crossbars/stringers, not intended to be weight bearing.
Yeah, that was the purpose of the wood blocks on top, to spread the load. I knew it was asking a lot. Re the other guy and pallets, I'll have to make a pallet for it, it's a 6' cutter. A normal pallet would just disappear underneath it.
   / Harbor Freight tools that DO suck #245
   / Harbor Freight tools that DO suck #246
Aaron Z
Yeah, I knew that'd be a problem, which is why I added the extra board piece. The problem with the brush hog is that it kind of comes down to a point in front, it isn't perfectly flat when it's fully "down". So it's very much a point weight, and of course the skid is only about 2-ish inches wide in the first place.
No doubt I'll constructing something else long term, I'm just dealing with short term problems at the moment. Meanwhile, I still expected that those black-covered dolly pieces were, you know, actual lumber, with wood grain and long fibers. Not wood chips glued together in a 1/2 inch or less mash.
   / Harbor Freight tools that DO suck #247
Our local Harbor Freight store is next door to Alro Steel.
I never go into HF. The place smells like Coronavirus.
Your experience may vary....
B. John
   / Harbor Freight tools that DO suck #248
B. John
So tell us, what does it smell like? Inquiring minds want to know....:laughing: I kind of thought Al Glick's place had a smell as well (Alro Steel).... Ar least the main plant (Jackson) does.
My all time favorite HF tool that really sucks is their ductile twist drills. Total junk but unbreakable. They just unwind.
   / Harbor Freight tools that DO suck #249
I had a couple of HF bits unwind long ago. Not recommended.
Or HF bits snap off. Twice I've tried to hog out a hole by wiggling the spinning drill, in soft material - sheetrock or something, hanging curtainrods - while using the drills with hex shank in a cordless screwdriver. Don't do that! Now I have two incomplete sets of HF's small hex shank drill bits. Real drill bits work better.
   / Harbor Freight tools that DO suck #250
Punches are junk too.
Status
2020 MACK P164T (A58214)
2020 MACK P164T...
JLG 1255 Telehandler (A56436)
JLG 1255...
2007 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A58017)
2007 INTERNATIONAL...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
2025 GPS Trailers (A56858)
2025 GPS Trailers...
LOT: Receiver Hitches, 1/2 Ton Sheet Clamp, Pipe Threader (A59076)
LOT: Receiver...
