Harbor Freight solar fencer question
/ Harbor Freight solar fencer question #1
ayelvington
Russell, PA
BX24
/ Harbor Freight solar fencer question #2
i hav e a zareba its a 6 volt fence charger on my garden fence, and then i attached a small solar panel to recharge the batteries, i would go with the zareba its a good machine.
/ Harbor Freight solar fencer question #3
I am wondering the same thing. I plan on starting a beehive and will need some protection against critters.
/ Harbor Freight solar fencer question #4
What are you intending to keep out, or in? If the one mention of critters, by 20 20, includes raccoons, well, to modify a line from the movie Jaws, "You're gonna' need a bigger charger."
I'm keeping out deer. The pressure isn't too bad in the area where the fence is, and I'm hoping the bite from it reminds them of the kick-butt charger I have on the other fence!
I plan to use the charger on newly installed fences and replace it with something more robust from Kencove. Like I said, I just need a short term solution.
So, anyone have experience with the Harbor Freight solution????
/ Harbor Freight solar fencer question #6
Are you sure you need the charger?
I put up an 8 foot tall fence around our 25'x50' garden years ago. The deer have not gotten into the garden which surprised me since the deer hang around the house and garden. They eat right up to the house exterior walls and the garden fence but they have not jumped over.
Later,
Dan
/ Harbor Freight solar fencer question #7
:laughing:
I think I'll have to go with something stronger, my critter problem will be with raccoons and their bigger helpers.......................bears
Later,
Dan
Deer pressure is pretty bad here, and I can't afford to lose the trees in the fence line. I see the charger as a cheap insurance policy! A neighbor saw a deer testing my other fence a few days ago, and was amazed at how far and fast a deer jumps when it gets a couple thousand volts the nose! (I wish I'd been there to see that.)
/ Harbor Freight solar fencer question #10
I hate to be the stick in the mud, but I have 4 Zareba solar chargers and the only one that works is the last one I purchased. I've tried changing batteries, but the chargers just don't seem to last.
You're not a stick-in-the-mud, and you're not alone! I've heard from several folks that the Zareba products and lemons...
Thanks!
al
/ Harbor Freight solar fencer question #12
I did recently purchase a solar panel off of e-bay for $60 bucks or so. It's for my GTO gate opener. It's working like a champ. GTO wants close to $200 for a lower end panel.
When I have a few min. I'm going to look for a 12vdc fence charger by itself. I'd like to provide my own battery and solar panel. I may even build my own voltage regulator for charging if it's not included.
This may be the more expensive way to go, but it beats buying a new charger every year. I haven't been able to find something more on the commercial side of solar fence chargers...maybe someone else has some experience?
Abe460
I did exactly what you want to do for my main area. I got a great DC fencer from kencove.com, and paired it up with two HF 15 watt solar panels, charge regulator, and a battery. I have the panels facing at different angles, so one catches the morning sun, and the other catches the afternoon sun. It works great, and the only effort was to knock snow off of them in the winter until I just shifted them to be straight vertical.
I just want a low-cost solution for about two seasons. So, I'm still hoping someone has experience with the HF fencer that I started the thread about...
/ Harbor Freight solar fencer question #14
I'm sure someone has some experience with the charger you are looking at.
I would pass it up based on the 6v/4.5 AH battery. For close to the same price you could get a 12v./7.5 AH battery. Replacement cost for the battery just doesn't seem to add up. I'd have to look again where I saw the 7.5 AH battery, but 12VDC to me, seems like the built in solar panel would be better suited.
I am by no means an expert. I just have my own little quirks.:ashamed:
P.S. I'd like to see what you have done with your panels and fence charger some time if you get a chance. I have an idea of what I want, but never saw an example...sounds like it works well.
I finally folded and bought the Parmak DF-SP-L1 solar powered fencer. Parker McCrory Mfg Co
My new problem is that the corner posts are bending under the stain of the high-tensile wire. I doubled them up as recommended, but just too much of a good thing. I'll be replacing them with driving wood posts when my cash flow improves...
I'm attaching some photos. You can see how the corner posts have bent. I'm going to put on a tape gate when it starts raining, and then transplant my trees into the area.
It's amazing how much you can learn from your mistakes!
/ Harbor Freight solar fencer question #16
Out of curiosity...what do you mean by a "tape gate"?
A tape gate is synthetic webbing laced with stainless steel fibers. It's about 2" wide and makes a very visible (and charged) barrier to the entrance. Insulated handles connect it to the charger so that if you disconnect it you don't have to fear getting bit by your own monster. I should take pictures, hunh?
Try this link:
Tape Gate 1.8in 16 ft White
/ Harbor Freight solar fencer question #18
Try this link:
That's kinda what I thought you meant. I have my entire stud pasture interior fenced with a 1" polytape, three rows. It's really good stuff, but I made the mistake of splicing with a knot and that doesn't work very well. If you've worked with it then you already know, but since I messed up I figured I'd pass it along to everyone.
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
2017 Hyundai Elantra Sedan (A61574)
2017 Hyundai...
2019 Ford Transit 350 Police Transport Van (A61573)
2019 Ford Transit...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
2022 EZ-GO ELITE...
