Harbor Freight PTO generator noise
   / Harbor Freight PTO generator noise #1
seijirou
Kemp, TX
17 Kioti CK3510SE HST, 23 Bobcat E35
I did search but didn't really find anything on this. Perhaps that right there is the answer to my question, but.
If you have a Harbor Freight PTO generator, how loud is it?
I'm surprised by how loud mine is. It is at least as loud as the tractor. Not so much that I can't run the thing, but enough that I'm on the fence it may not be normal. However I have absolutely no baseline to compare it to. The noise has no correlation with the load.
   / Harbor Freight PTO generator noise #2
The cheaper PTO generators are 2-pole units, and spin at 3600rpm. So they whine something fierce. That is normal. You pay more, and larger PTO generator which are 4-pole genheads spin at 1800rpm.
Okay, thank you. Whining something fierce is exactly what it does. I got this at a deep discount so I still have the option to sell it. If I do I was looking at the IMD PTO 22/2 S AVR. Do you happen to know if those are the 4-pole variety? IMD PTO 22/2 S AVR - 22kW Tractor-Driven PTO Generator w/ AVR 540 RPM
   / Harbor Freight PTO generator noise #4
Umm, I don't know. I would make contact and ask. Usually a 4-poll genhead is a major selling point. Say you go to the Baumalight PTO website, they list 2-pole units, and 4-pole units.
4-pole 30kw unit running a 19kw load.
Okay thank you. I see it now. The 4-pole are significantly more expensive so the 22kw IMD must also be a 2-pole. Thanks for your insight.
(2) GAS HEATERS (A54757)
(2) GAS HEATERS...
UNUSED IRANCH SEMI-AUTOMATIC MINI QUICK COUPLER (A57193)
UNUSED IRANCH...
Crate of Misc Lawn Equipment (A56469)
Crate of Misc Lawn...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
2022 JOHN DEERE 330G SKID STEER (A52707)
2022 JOHN DEERE...
