Harbor Freight paint guns?
/ Harbor Freight paint guns? #21
I see the $40 gun, the one with a regulator, in their Dollar Days ad (page 5) for $25. Sale ends 1/22.
The one Sully2 pictured is occasionally as low as $10.
/ Harbor Freight paint guns? #22
The guns are almost piece for piece identcal except the regulator....but if you watch close...you can sometimes pick up that reg for $5 on sale. I bought a different model mini regulator for $5 on sale from them instead.
/ Harbor Freight paint guns? #23
charlz said:
I see Harbor Freight has some paint guns in their ad. I was thinking I should get one for painting implements I make, maybe a tractor some day. Anybody use their paint guns? Which one(s)? Are theirs any good? What to look for in a paint gun? I have never actually used one so.....
Thanks!
Charles
I have 3 of their guns.. got one over 5ys ago.. appears to be a cheap 'Binks' knockoff.
it was a 14.99 gun at the time.. but marked down to 9.99$.. I bouhgt it and have use dit up till last year,.. I have now relegated it to solely be a primer gun, and then bought a new one for paint.. and a 1-cup touch up gun for small jobs.
Key is adjusting them.. then ALWAYS cleaning them like they were a 300$ gun.
The insids and all air holes on my 9$ gun are squeaky clean... and that makes it keep working..
soundguy
/ Harbor Freight paint guns? #24
Can you get a replacement 20 oz. cups for them? bjr
/ Harbor Freight paint guns? #25
I have about a thousand dollars worth of paint guns in my cabinet. I have two gravity fed guns that I mainly use. One I use to spray primers and most industrial paints. It's a $140 Sharpe. A buddy of mine has one of the HF knock-offs for $40 and it works just as well as my high dollar Sharpe.
For top coats and high grade finishes, I use a $600 Sata. The Sharpe or HF knock-off can't compete with it, but unless you are painting show cars, it doesn't matter.
For the money, you have to go with the HF guns for basic painting needs.
/ Harbor Freight paint guns? #26
You CAN...but the only ones Ive been able to get are all aluminum instead of .."plastic"...$14.95 and Ive never seen them "on sale".
/ Harbor Freight paint guns? #27
I have this one...
Harbor Freight Tools - Quality Tools at the Lowest Prices
Used it to paint the trailer. Just thinned some black rustoleum, worked great. I cranked up the pressure to put on more paint faster. $17!! I was planning on tossing it after the paint job but it cleaned up nicely and is on the shelf. I use a Binks Mach I HVLP for my furniture. Not sure if there is that much difference.
/ Harbor Freight paint guns? #28
I got one of the 25$ HVLP gravity feed with regulator setups from Cummins traveling tool sale i got it to paint one truck and it did a very good job id rather pay 25 for a cheap china spray gun that pay 80 for the same setup at walmart home depot etc
Its identical to the husky at HD and several of the Harbor Frieght setups
/ Harbor Freight paint guns? #29
I bought their HVLP spray gun a year ago when it was on sale for $45... I've only used it for spraying clear lacquer on furniture, but I am impressed with it, especially for the money. I don't know how well it would work with thicker finishes, considering you can't change out the nozzle, but for thin paints, it's good. Seems to be well made, and cleans easily.
