Harbor Freight Jack
   / Harbor Freight Jack #1
buck12
Veteran Member
Mississippi
Kubota 5460HSTC
Has anyone purchased a Harbor Freight floor jack? They have a three ton Pittsburgh on sale for $79.99. I don't use a jack often but need my old one is leaking I generally don't buy Harbor Freight tools but I hate to pay $150 or $200 for an item that is seldom used.
   / Harbor Freight Jack #2
Bought 1 from NAPA 2 ton( 150.00 ) several yrs ago it was made in China & started leaking about 2 yrs ago. Bought 1 from HF 3 ton(80.00) 2 yrs ago ( made in China) still going strong
   / Harbor Freight Jack #3
I've had the 3 ton HF Pittsburgh jack for about 6 months. Works great (fingers crossed).
   / Harbor Freight Jack #4
I bought a 5 ton long reach floor jack from them and it crapped out after a couple of years of light use. It's sort of a crap shoot with their stuff. I have an impact wrench set that has been going strong for 10 years. I have some good luck and some bad luck with their merchandise.
   / Harbor Freight Jack #5
My advice, never buy cheap tools when you life might depend on them (like a jack failing and crushing a body part).
I bought an el-cheapo 3 ton jack, it had enough guts to lift my F250 crew super duty during a tire change. But as I was trying to line up the stud holes, the jack failed. It started leaning and crumpled - ejected the jack smacking the back of the tire and rim while the truck slammed to the ground.
The LT tire/rim was pretty heavy, and with my back issues I had sat on the ground cross-legged and was using only my arms to lift the tire. Had I extended my legs - could have been crushed.
The truck was parked along side a road. (isn't ironic you never get a flat tire at home?) The road surface was only a few degrees off level....but with me pushing on the spare it was enough to cause failure.
So I decided right then - no el-cheapo jacks ever again.
Dean
   / Harbor Freight Jack #6
I never work on a jacked-up vehicle without jackstands- period. I also leave the jack in place in case the jackstand fails!
I bought a cheapie at Sam's ($60 or so) about ten years ago, and it's still going strong. My hydraulic engine hoist, however, goes through cylinders like crazy. I just keep buying a new cylinder every couple years.
   / Harbor Freight Jack #7
Check Northern Tools when they have a sale. Jacks are usually extreemly cheap and a pretty good product. Mine have lasted quite a few years.
I thought I should update this thread. I bought the Harbor Freight 3 ton jack (actually got it for Christmas). It appears to be a decent jack.
   / Harbor Freight Jack #9
I have several of the HF jacks and have had them for several years now, a couple bottle jacks, the aluminum racking floor jack and the farm and ranch hi lift jacks. I have not had any issues with any of them For safety, I never rely on just a jack alone in lifting and supporting anything while I am working on it. I always carry wood blocks in my truck and in the shop I use jack stands.
I have a set of jack stands somewhere. All I ever use is wood blocks. Just gives me better feeling than the a jack stand.
LOT: Fuel Transfer Tank, Tool Box, 12 Volt GPI Pump (A59076)
LOT: Fuel Transfer...
2007 Tymco 500X Air Sweeper, Turbo Diesel, 3876 Hours Indicated, mounted on 2007 International 4200 (A59076)
2007 Tymco 500X...
1999 International F-4900 T/A Cab and Chassis Truck (A56858)
1999 International...
KENWORTH W900B (A58214)
KENWORTH W900B...
2015 Jeep Compass SUV (A56859)
2015 Jeep Compass...
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
