Harbor Freight Jack
/ Harbor Freight Jack #1
buck12
Mississippi
Kubota 5460HSTC
Has anyone purchased a Harbor Freight floor jack? They have a three ton Pittsburgh on sale for $79.99. I don't use a jack often but need my old one is leaking I generally don't buy Harbor Freight tools but I hate to pay $150 or $200 for an item that is seldom used.
/ Harbor Freight Jack #2
Bought 1 from NAPA 2 ton( 150.00 ) several yrs ago it was made in China & started leaking about 2 yrs ago. Bought 1 from HF 3 ton(80.00) 2 yrs ago ( made in China) still going strong
/ Harbor Freight Jack #3
I've had the 3 ton HF Pittsburgh jack for about 6 months. Works great (fingers crossed).
/ Harbor Freight Jack #4
I bought a 5 ton long reach floor jack from them and it crapped out after a couple of years of light use. It's sort of a crap shoot with their stuff. I have an impact wrench set that has been going strong for 10 years. I have some good luck and some bad luck with their merchandise.
/ Harbor Freight Jack #5
My advice, never buy cheap tools when you life might depend on them (like a jack failing and crushing a body part).
I bought an el-cheapo 3 ton jack, it had enough guts to lift my F250 crew super duty during a tire change. But as I was trying to line up the stud holes, the jack failed. It started leaning and crumpled - ejected the jack smacking the back of the tire and rim while the truck slammed to the ground.
The LT tire/rim was pretty heavy, and with my back issues I had sat on the ground cross-legged and was using only my arms to lift the tire. Had I extended my legs - could have been crushed.
The truck was parked along side a road. (isn't ironic you never get a flat tire at home?) The road surface was only a few degrees off level....but with me pushing on the spare it was enough to cause failure.
So I decided right then - no el-cheapo jacks ever again.
Dean
/ Harbor Freight Jack #6
I never work on a jacked-up vehicle without jackstands- period. I also leave the jack in place in case the jackstand fails!
I bought a cheapie at Sam's ($60 or so) about ten years ago, and it's still going strong. My hydraulic engine hoist, however, goes through cylinders like crazy. I just keep buying a new cylinder every couple years.
/ Harbor Freight Jack #7
Check Northern Tools when they have a sale. Jacks are usually extreemly cheap and a pretty good product. Mine have lasted quite a few years.
I thought I should update this thread. I bought the Harbor Freight 3 ton jack (actually got it for Christmas). It appears to be a decent jack.
/ Harbor Freight Jack #9
I have several of the HF jacks and have had them for several years now, a couple bottle jacks, the aluminum racking floor jack and the farm and ranch hi lift jacks. I have not had any issues with any of them For safety, I never rely on just a jack alone in lifting and supporting anything while I am working on it. I always carry wood blocks in my truck and in the shop I use jack stands.
I have a set of jack stands somewhere. All I ever use is wood blocks. Just gives me better feeling than the a jack stand.
2017 Autocar Xpeditor T/A EZ-Pack 40Yd Front Loader Garbage Truck (A61568)
2017 Autocar...
2015 Lincoln MKC SUV (A61569)
2015 Lincoln MKC...
Jack Daniels Mini Decorative Truck (A61569)
Jack Daniels Mini...
UNUSED ATS EPC40 ELEC.PLASMA CUTTER (A62131)
UNUSED ATS EPC40...
BUSH HOG 3715 BATWING ROTARY MOWER (A62130)
BUSH HOG 3715...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
