Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,424
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
rjgogo said:what you have there can easily be done with a tombstone and stick and KNOW that it will last but still look as bad. 60XX rod may look like crap but it penetrates. With the HF machine I would not trust it.
I'd wager that a 1st pass with a 1/8 6011 rod, followed by a 2nd pass with a 6013 rod may actually produce a -better- looking weld, with perhpas 100% penetration. Heck.. the 6013 may have given just as much penetration as the 1/4 plate could take anyway, and still look like a row of dimes.. even on an ac stick welder.
When I ended up buying my welder.. i went cheap.. ac only.. not ac/dc.. but I only do odd projects. TSC's 239$ hobart 235a stick welder was a hard deal to pass up. With the thin stuff I weld.. i can run 100% duty cycle too.
Still .. if I ever find a good mig cheap.. I may have to get it. I've used ours at work.. a 200+ amp unit using 25/75 gas mix.. and it's slicker than snot..
Still. in the end.. I built my HD trailer ramps using 1/2" angle and plate, and used a big lincoln tombstone to do it.. and I'm sure the welds are good.. no matter what they look like..
Soundguy
