Travelover
Elite Member
I've seen these at Home Depot, Lowes and Ace hardware in their special fastener drawers.
My plastic handles were worthless. The welded nut on the inside of the legs was welded at a slight angle on both sides. so the machine screw bound slightly do to the friction caused by rubbing on the os of the hole on the other side of the leg.
I just picked up the Welding Table. Seems like its pretty solid to me. The stupid plastic 'handles' will probably get replaced with HF 13mm wrenches welded on the bolts when the break (or even a piece of flat stock).
I did just find this that may prove to be useful with the table (although some minor modification may be needed for it to work right)
9" Drill Press Locking Clamp
As for the cabinet.... I sure wish they had that back in December/January when I was buying carts for my welder and plasma cutter :-( I would have got at least one....
When I bought my table I also picked up this cheap vise for $17. It's great for holding small pieces for welding or grinding and since it rotates in both axis you can position the work where you want it. Its made to clamp to a thick table top but I used a 1-1/4 nut as a spacer under the table to make up for the thin metal top. Works well and very sturdy.
I've had the table for a few weeks, overall it's been pretty good. But one of the plastic leg pieces split in half and fell off... A rocking 3 leg table was not very useful so a little duck table is holding it on until I come up with something better.
Great idea. This could even work on a sewing machine.A rocking welding table is a brilliant idea. What a great way to get perfectly stacked dimes or a perfect Z motion. Hold the electrode in place and use your foot to rock the table while an assistant pushes the table along the axis of the weld. Maybe use an HF winch to do that.
