Harbor Freight air ratchet
   / Harbor Freight air ratchet #1
RobJ
Elite Member
Spring, TX (Houston)
Kubota L2500
My 30 year old Blue Point air ratchet finally broke. Some little metal ball came out from somewhere in the head and it just has no power. Not sure if it's worth fixing. So I order the HF 19.95 model with a few other ods and ends. I think it's the same one I have up at the weekend place and used it a couple times. Low and behold I might be able to fix the old BP. Can you say copy?? I'mm have to see wha kind of power it has. My old Blue Point would lock your hand against a bracket with the power...and nothing was slipping!!! Might just put it on Ebay and see if someone else can fix it.
Rob
   / Harbor Freight air ratchet #2
The Harbor Freight ratchet has about enough power to screw a bolt in Jello.
Mine has worked fine for years, but just don't get too optimistic about the torque. Try to fix the Blue Point.
   / Harbor Freight air ratchet #3
The outside may look the same but it's what's inside that counts.
I have the same Blue Point but it's only 23 yo and all that I have had to do to it is replace the rubber button that shuts off the air.
2020 FREIGHTLINER 26' BOX TRUCK (A51247)
2020 FREIGHTLINER...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2024 New Holland T8.410 MFWD Tractor (A53473)
2024 New Holland...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
LMC G500-500A LOT IDENTIFIER 94 (A53084)
LMC G500-500A LOT...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
