Harbor Freight Air Compressors
   / Harbor Freight Air Compressors #1
RichZ
White Creek, New York, Washington County, on the V
Kubota 4630 with cab and loader
I need a new air compressor, and I don't want to spend much, as it isn't going to get heavy use. Mostly to fill tires, occasionally to run an impact wrench when I rotate tires, and to run my pneumatic goat hoof trimming shears.
In the February flier, they have 2 small compressors on sale for $64.99 each. Each is a 3 gallon; 970880 standard design and 95275 pancake. Has anyone had an experience with either of them?
They also have 67696, 6 gallon 150 PSI "Professional" air compressor on sale for $99.99. Anyone have any experience with that one?
Thanks!!!!
   / Harbor Freight Air Compressors #2
Never used the ones you've mentioned, but I have this one:
Portable Air Compressor - 2 HP, 8 Gallon, 125 PSI
IIRC, I paid $89 for it, on sale. It's been really good, so far. I've probably had it 5 or 6 years, and it's been used a bunch. The only trouble I've had is the off/on switch has just about quit working, but I just unplug it when finished.
   / Harbor Freight Air Compressors #3
   / Harbor Freight Air Compressors #4
Thanks!!!!
I don't have any experiences with their compressors. but, I have a friend that has the small pancake ones & he complains that they take too long to build up any pressure.Ie: it will build to 125 psi but, it takes a while to get there
2004 PETERBILT 379 9 CAR HAULER (A52577)
2004 PETERBILT 379...
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
2019 RAM 3500 (A52472)
2- 30 X 42 TRIANGLE PIPE RACK (A52472)
2- 30 X 42...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
378651 (A51573)
378651 (A51573)
