3-Point Hitch Harbor Freight 3pt quick hitch & BB2060
   / Harbor Freight 3pt quick hitch & BB2060 #1
Andy man
Buckley, WA
John Deere 2520
Anyone out there using this set-up?
   / Harbor Freight 3pt quick hitch & BB2060 #2
no, but I have been eyeballing the quick hitch, it's alot cheaper than the imatch and looks to be a little more versatile.
   / Harbor Freight 3pt quick hitch & BB2060 #3
Hi:
I bought 2 of them for $69 each from HF. Then I bought a real I-Match for about 200.
Problems. the adjustable top hook makes it wider. TOO wide to fit into some implements that have a narrow channel for the top link (The hook won't be able to go into the TL area). This is a biggie and without grinding off the brackets (Certainly possible) with the holes and welding the hook back I have implements it doesn't fit. If all of your implements have a large space between the top link bracket you'll probably be fine. I can't remember if it was the BB that it didn't fit but I think it was.
Fit/finish - I had to grind the top link hook to get it to fit the top pin in those implements that it DID fit.
The lower hooks I don't think are big enough for the JD bushings (minor) - You could grind them out.
With a little work you can make it work. It is pretty rugged. I bought one to fabricate a loader mount implement mover (I have the hooks and pins from JD to weld on) - Just haven't gotten around to it yet.
It's sure a steal for the price.
   / Harbor Freight 3pt quick hitch & BB2060 #4
I have had the imatch and BB2060 since day one because that is how I ordered my tractor but I have subsequently visited harbor freight and examined their quick hitch. At first, I was shocked at how much cheaper the HF hitch was compared to what I paid and thinking that I overpaid on the imatch but after looking at the HF product up close and operating the levers, I am of the opinion that there is no comparison with respect to the quality between the two hitches. $200 vs. $69 is certainly not an "equal" comparsion but I like quality in my equipment and if I had to do it again, after viewing and operating both, I am happy that I went with the imatch. I can not comment on how well the HF product actually performs in the real world as I only operated it at the store. However, the levers are much sloppier, and the fit and finish leaves much to be desired.
   / Harbor Freight 3pt quick hitch & BB2060 #5
I agree with Superduper, I saw that $69.00 at TSC , and it just does not have the build quality the IMatch seems to have. I usualy use JD attachments. and everything fits with ease. if i buy a tool that wont fit. I can easily weld and fab it to fit my IMatch with no problem...;)
Chris...:)
   / Harbor Freight 3pt quick hitch & BB2060 #6
I have a JD 790 and bought the Harbor Freight Quick Hitch out of economics. I paid $59.00 for mine from a 20% off HF coupon I found on this website. Also to reduce implements hook up time.
Summary:
It suits my purposes. Light bushoging. Quality is good. Will need painting eventually. But, on a farm, this is to be expected. Will need to get an adapter hitch for the top link (extra $8 bucks) from Harbor Freight (usually all quick hitches need this adapter link to work all implements). If it is due to economics why you are considering it, it is a good deal for the money.
Sincerely,
Ikymojoe
   / Harbor Freight 3pt quick hitch & BB2060 #7
thanks for the heads up guys...I bought a Green tractor because of the quality, I might as well spend the extra $$$ on the imatch too
   / Harbor Freight 3pt quick hitch & BB2060 #8
I bought the HF and couldn't be happier. John got nf of my money and there just isn't much difference between the 2 hitches.
   / Harbor Freight 3pt quick hitch & BB2060 #9
Well said, I couldn't agree more.
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
PALLET OF PORTABLE AC UNITS (A51248)
PALLET OF PORTABLE...
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
