Harbor Freight 3500# Winch to RTV 900?
   / Harbor Freight 3500# Winch to RTV 900? #1
LarJea
Mt Rainier
farmall h and Kubota B2601
Does anyone know if Harbor Freight's 3500# winch will bolt up inside the front bumper? They are on sale for $89.00 with coupon.
   / Harbor Freight 3500# Winch to RTV 900? #2
Don't know about bolt up but you get what you pay for...Not sure I'd even try it with a machine that heavy.
   / Harbor Freight 3500# Winch to RTV 900? #3
I agree w/timswi; but I'm going to offer too much information as usual :D
The 3,500# advertised rating is the absolute maximum achievable value under perfect conditions such as sufficient electrical supply, new bearings, and a spool with only 1 wrap of wire; some load tests are done for less than the length of the cable or on paper, so some (if not most) winch-capacity claims are tenuous at best.
I think it is more important to match the electrical requirements of the winch to the electrical aspects of the vehicle; if the winch needs a certain amount of "amps"to run properly, make sure your vehicle (battery & alternator/generator) can produce it for an hour or more.
A fully-loaded mired vehicle like yours can easily exceed 3K pounds (more if on a slope) plus the weight of the rigging, so carry at least 3 snatch blocks regardless of the winch you end up with.
There is some good math in this pub:
http://www.northeastohio4x4.com/pdf_files/army vehicle field manual.pdf
http://www.extension.purdue.edu/extmedia/PPP/PPP-98.pdf
Ok, thanks for the information. I have a truck and a jeep with winches and a excavator in case I get into trouble. I just thought I could use a winch on the RTV 900 for smaller chores. I suppose I could wait and buy a warn 3500# winch instead. I would like to bolt in a larger winch but I don't believe it would fit inside the bumper so I can still use the snow plow.
   / Harbor Freight 3500# Winch to RTV 900? #5
In SC that winch is currently 139.00. Where did you get such a great coupon? Maybe HF sends out different sales ads in different parts of the country. I'd like one of those great coupons myself!
   / Harbor Freight 3500# Winch to RTV 900? #6
I had a 4,000 lb Warn on my 900 and then moved it to my 1100 with no problems.
Check Warns site for the length and width, then measure HF model.
If the dimensions are close enough it will probably fit.
Getting to the end switch on the Warn was tight.
With a little work, drilling holes, you can make almost any winch fit the plate that is there or get one cut.
I never had to use my winch for what I would call real work, like getting unstuck.
So really, why not get the good deal, fit it up and see what happens.
Chances are you will get along just fine.
Hiptfarms: My wife thru out the harbor freight coupon sales paper, but I will check with a couple friends and see if they have a copy.....SpudHauler: I think I will take your advice, (providing I can get another $89.00 coupon).
   / Harbor Freight 3500# Winch to RTV 900? #8
Thanks for checking.
I found another Harbor Freight coupon for the 3500 lb. winch, if you are interested, for $99.99. Coupon code #55801290 on their website or call 800 423 2567. I am going to wait and hold out for the $89.00 coupon, if and when that happens again.
UNUSED CFG INDUSTRIAL SSECAG-Y HYD AUGER (A51248)
UNUSED CFG...
2005 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCEC19V35Z257979 (A51573)
2005 Chevrolet...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
Approximately 250 Traffic Cones (A51573)
Approximately 250...
19200 (A50324)
19200 (A50324)
