Happy, Unhappy with my PT
   / Happy, Unhappy with my PT #11
Happy
(but my real response if I could, would be, happy when it is running the way it should...can't stand the thing when it is not running the way it should)
   / Happy, Unhappy with my PT #13
Satisfied and content.
I have noted that different parts break for different users. I have not had the problems that some have had. But I have replaced the seal in the steering valve and the seal in my tiller motor. Both problems are rarely noted on this board. It appears that no one component is failing for everyone. The PT is assembled with off the self components. Due to the luck of the draw some of those parts fail sooner than others.
Dale
   / Happy, Unhappy with my PT #15
Happy (somewhat extremely moderately happy)
Problems to date:
1) Hour meter quit at 235
2) Blown head gasket (Kohler) at 350 hrs
3) Two Wheel motors (white) destroyed
4) broken welds on lift arms - eventually replace entire assembly
5) numerous flats on tractor from poorly designed dual valve stems
6) numerous flats on mower - went to solid wheels
7) broken welds on mower deck
8) leaking hydraulic oil tank
9) constant problem with 6 way valve for lift arm/aux
10) Mower deck blades - coming loose every time I mow
11) numerous flats on 2 ply tires - went to 6 ply
Money spent to fix all these problems - about $2.2K over 4 years.
Do I like the machine? Love it, just wish it was less prone to breaking.
-Tim
   / Happy, Unhappy with my PT #16
Very Happy!
Over 400hrs of hard use & abuse. No major failures.
Gravy
   / Happy, Unhappy with my PT #17
BobRip said:
I would like to take a vote on who is Happy and who is Unhappy with their PT. Please respond with Happy or Unhappy and nothing else. Please only vote once and no other comments.
Happy
HAPPY
(Like a person with anthrax when his neighbors have terminal cancer)
   / Happy, Unhappy with my PT #18
Happy.
Only one problem...leak in fuel tank outlet. Easily fixed.
   / Happy, Unhappy with my PT #19
catsco said:
HAPPY
:D:p:D:p:D
That is sooooo funny, and says so much.
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
15 TON GRAIN BIN (A57192)
15 TON GRAIN BIN...
Booster Cables (A55852)
Booster Cables...
UNUSED FUTURE HYD AUGER (A57193)
UNUSED FUTURE HYD...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
UNUSED FUTURE BS72 72" HYD BOXBROOM SWEEPER (A57193)
UNUSED FUTURE BS72...
