Dadnatron
Veteran Member
OK... I give.
I believe I know the problem, but have not determined a solid cure.
I知 hanging 16 and ?0 tube gates on newly built fence. 8 posts driven into the ground 3+feet.
Gate 1 went well and gate hung correctly. Moved to gate 2...and the wheels fell off.
I believe I inadvertently drilled the holes just slightly out of parallel, which causes the gate to 喪un down hill as if it is out of level. I can get it perfectly level when closed, but upon opening, it is clear there is a problem. The top hinge bolt is slightly to the open side, compared to the bottom hinge. The holes are correctly started and distance is correct, but after inserting the bolts, they clearly are not in exactly the same alignment. I壇 say they are off by 3-5*. This results in the protruding portion being offset and thus, the gate falling open.
When drilling the holes, it 都eems like they are parallel, but the results show differently. I drew é¼*ines to follow etc, but the bottom hole seems to be the one which is å�Œff? When I知 down on the ground drilling a hole 13 off the ground on a 5 post, the angle is getting off slightly and messing things up.
Now that I have the holes drilled I知 in a quandary.
1. Do I redrill the top hole higher, moving the hinge on the gate, but trying to get it parallel to the bottom direction?
2. How do I insure both holes are drilled parallel?
Any thoughts would be welcome.
