Hanging Equipment On Trailer
   / Hanging Equipment On Trailer #1
Daves3032E
Middlesex, NY
John Deere 3032E
I am getting a new 16 ft gooseneck dump trailer to replace my 18 ft utility trailer. Every two weeks I travel about 75 miles away to my sister in laws and I take my tractor and whatever equipment I can to get firewood out of the woods from a location near her house. I leave all of the wood at her place and sell from her house.
The problem I'm running into is transporting everything. I have my saws and related equipment that can go in the bed of the truck. I have my root grapple, bucket, 3032e, carry all forks/rack, log splitter, 3 point log grapple, and logging winch. I currently try to judge what I will need on my next visit, but sometimes I would like what I didn't bring... you know the problem. Pack up everything that you think you'll need, but realize you ended up needing that one thing that you didn't bring.
I also want to build a small forestry/forwarding trailer to get more wood to the landing at a time. Where would I put that??? It wouldn't be huge, around one that would work behind an atv.
I was thinking I could take the sides off the trailer and lift it on its side and hang it on the side of the dump. Has anyone had good luck with that kind of arrangement? What else could I hang on the outside? I think that as long as I keep it pretty close to within the width of the trailer that it would be ok. It's not a deckover dump.
   / Hanging Equipment On Trailer #2
Why do you choose to drag everything back and forth? Could you not leave one or two items locked up at your sisters? My Crysteel dump truck bed has what is called a triple tipper on it. The hoist is in the center and you have pins that attach on three sides and the pinned location determines the dump. Gravity brings the bed back down. As long as the object weights less then half the bed it would be picked up when lowering. In the case of hanging things on the side; I would then pin it off in the rear location.
I transport it all because I also have wood to take care of at home and two other locations depending on the day of the week.
   / Hanging Equipment On Trailer #4
One of the main reasons I got aweigh from goosenecks. The use of my truck bed is to valuable. I am lucky pull with 3500 DW. So it works well for me.
   / Hanging Equipment On Trailer #5
How about adding a second trailer.
My late father in law towed a fifth wheel camper and boat trailer together quite often
I wish I could, but I don't believe that is illegal in NY.
   / Hanging Equipment On Trailer #7
This is the very reason I dumped my GN. I quickly learned I needed twice the trailer once I deducted my bed space.
Chris
   / Hanging Equipment On Trailer #9
sounds like you need a larger trailer not smaller.
Sounds like the best thing for you is a combo trailer in the 22-24' length. 14K pumper pull with WD hitch on the back of a 1 ton sounds about right.
   / Hanging Equipment On Trailer #10
Ignore everyone complaining about the GN's. They didn't have a big enough trailer to begin with if they are griping about bed space. They tow more weight easier to. If you had a large enough trailer, there wouldn't be bed space issues There is a reason semi trucks don't tow large trailers off the rear of the frame. (Yes I know there are pintle trailers, but they are relegated to smaller equipment)
If the dump trailer is deep enough, can you fab a rack to stack things inside?
2025 CFG Industrial QK16R (A50123)
2025 CFG...
Case TV380 (A50123)
Case TV380 (A50123)
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2025 CFG Industrial H15R (A50123)
2025 CFG...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
