Handy Trick For Moving Trailer
/ Handy Trick For Moving Trailer #1
keeney
Minnesota
JD 4100 HST
I needed to move my fishing boat out of the way of some construction activity on my property. Problem was, the normally light-weight boat and trailer was very tongue-heavy because a bunch of water had collected in the front of the boat and was frozen there.
It was too heavy to lift the tongue up to the ball on the drawbar by hand. The trailer doesn't have a tongue jack on it because normally its light enough to just lift onto the hitch by hand.
I had the idea that I could use the 3-pt lift arms some how to lift the trailer tongue. Turns out, its really handy to just hook the trailer safety chains over the edge of the lift arms, one on each side and use them to lift the tongue up. I had to wrap the chains around the arms about 1 full turn to get the length right.
Hop back on the tractor, back up a few inches, then lower the tongue onto the ball for a strain-free way to hook up the heavy trailer to my tractor without fetching any other tools.
I left the chains hooked while transporting (see my previous post concerning a near-incident with a run-away trailer) and it was just as easy to lift it back off.
- Rick
/ Handy Trick For Moving Trailer #2
Any seen attachable tractor tongue props?
I'm looking for an attachable tongue prop to put on my Gravely cart for when I get my 4wd tractor, to prop it while I load (or empty) it with the FEL. Then reattach to the tractor to move it.
Anyone seen them for sale that'll attach to my cart tongue? It's basically a 1 1/2" steel pipe.
Ralph
/ Handy Trick For Moving Trailer #3
Re: Any seen attachable tractor tongue props?
RV stores have diferent kind of screw jacks that may work for you.
I use a block of wood and have the ball mounted on the three point. Place the block under the tongue, lower three point and drive away. For hook up reverse the procedure.
Egon
/ Handy Trick For Moving Trailer #4
That trick could inspire a scene on the Simpsons if it wern't frozen and the tongue was lifted enough for more water to go to the back of the boat. (Most 3PH's are held down by gravity)
/ Handy Trick For Moving Trailer #5
One item that is pretty handy is "hitch bar" that spans between the 3pt .
They're sold at many tractor supply places and were used extensively years ago with 8n, 9n Fords, old Fergies etc.
The last one I bought was about 35.00.
fyi- They're just a piece of steel bar about 2.5" wide by 1" thick with a series of holes (8) along the bar to accept a pin, ball or clevis.
The bar fits between the 3pt arms.
GrayBeard
/ Handy Trick For Moving Trailer #6
at any tractor store you can by the draw bar for 10 or so bucks. Then put on an old ball. Should be able to do it for less than 15.
/ Handy Trick For Moving Trailer #7
I'd assume if the ice was water one would pull the plug and lift up the front. Think most plugs are near the back of the boat.
And remember; the ball hitch locks on while the tree point will only go so high.
Egon
/ Handy Trick For Moving Trailer #8
I'm not going to quibble about whether the water can get out the drain hole as fast as it can get to the back of the boat. The main point is, a 3PH mounted drawbar, ball or no ball, shouldn't be used for a trailer if the center of gravity can ever shift to behind the trailer's axle. That includes tilt trailers, dump trailers, cars on trailers you're going to unload without ramp support, boats on trailers that kids may play in, trailers that are unloaded front first, and so on. If nothing is holding down the tongue, nothing is holding up the rear.
/ Handy Trick For Moving Trailer #9
That pretty much goes for any type of towing. Although, I might add, they do have safety chains for the 3PH that keeps the tongue for flying up.
<font color="green"> That trick could inspire a scene on the Simpsons if it wern't frozen and the tongue was lifted enough for more water to go to the back of the boat. </font>
Been there, done that before in the summer. Funny thing is, once you get enough water in the back, it will sit there for tewnty minutes or so with the front of the boat up in the air and the back sitting on the ground while the water drains out. Then it tips back down and the remaining water slops into the front again.
Once I hade the tongue lifted, I connected it to a ball on the regular drawbar of the tractor, not one on the 3-pt, so once it was connected up, there wasn't any chance of the weight shifting in a dangerous or unexpected way.
The problem of putting a block of wood under the tongue is that you have to remember to do it when you set the trailer down, before the boat gets full of water.
- Rick
/ Handy Trick For Moving Trailer #11
Shuckins; here I've been pulling a trailer around for years with the three point and now I'm suppossed to change.
Egon
/ Handy Trick For Moving Trailer #12
Dad got 2 old (I'm assuming for the N series Fords) swinging, telescoping 3pt drawbar hitches and slightly modified them to fit on a bigger 3pt arm. Really a wonderful adjustable hitch when you can move it in 3 axis' for hooking up! I've been using them for 25 years or more.
With that said, it can be _very_ dangerous. Going down a hill (I have many) or trying to stop fast or using a 2-wheel tail-heavy trailer....
If you leave the hitch kinda high & I'm pulling a 200 bu farm wagon (12,000lbs) and go down a hill, the wagon pushes me - a lot. Since nothing is holding down the hitch, it swings up to maximum height - kinda fast. With the angle of the hitch, the hitch pin gets sheared off, with the wagon pole sort of aimed for my head now - and 12,000 lbs pushing in that direction.
This is a serious, real, very dangerous situation. I must think of it every day & keep the hitch low in such conditions.
It really, really takes your breath away when that 3-point slams up! Don't take this too lightly.
I understand the original poster had a safe condition & is only using the 3pt to lift the hitch to couple onto his solid drawbar. Just want the others reading this to think their actions through so they don't put themselves in harm's way. Those 3-point drawbars are real convienient, but when you are around a tractor & machinery always think through the bad things that can happen, and plan for it.
--->Paul
/ Handy Trick For Moving Trailer #13
I couldn't agree more with rambler.
When I mentioned about the 3pt drawbar it goes without saying safety comes first with any machine or "rigging "operation.
The 3pt does give versitility as compared to the "standard" draw bar. Years ago I did alot of work with a 3pt bar. I wasn't implying its use exclusively over a regular draw bar.
You just have to understand the limitations.
GrayBeard
/ Handy Trick For Moving Trailer #14
Restraining the 3-PTH from comming up while towing...
Bad River Inc. makes a nice receiver hitch assemble...
the chain attaches to the the top of 3PTH and the "fixed" drawbar under the rearend...
Dave...
/ Handy Trick For Moving Trailer #15
One thing to watch for on those bars is the holes in a cat 1 bar are about 7/8" so you might have to get a smaller shank ball. You can find those at any decent farm store. The one I use on my truck for example has a much bigger shank.
This is a pretty neat alternative to using the 3ph.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=45238
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2008 Ledwell LW48HTHT2 48ft. 40 Ton Hydratail T/A Step Deck Trailer (A64194)
2008 Ledwell...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
2000 Ford Windstar Van (A64557)
2000 Ford Windstar...
Metal Gulf Gasoline Statue (A64127)
Metal Gulf...
2003 Dodge Ram 1500 Crew Cab Pickup Truck (A64556)
2003 Dodge Ram...
