Backhoe hand throttle not working
   / hand throttle not working #1
samr12
LAUREL,MS
NT204C
hello,
I have a nortrack nt204c and the hand throttle does not rev engine, when moving it, feels like it does have some tension, looked at diagram in manual but cant figure whats moved,broken or missing?
thanks sam
   / hand throttle not working #2
It sounds like the rack is stuck or the governor has issues. How is the oil level in the fuel injection pump?
will have to get the manual out to see how to check the inctector pump oil and get back to you thanks bob.
didn't know but going to mention that accelerator pedal work fine
thanks sam
   / hand throttle not working #5
thanks sam
They should both connect to the same place. Sounds like a broken linkage.
With the engine off, push the pedal and look at what moves. Then move the hand throttle and see what moves and what doesn't.
2025 CFG Industrial H15R (A50123)
2025 CFG...
2013 Yamaha YDREx4 Electric Golf Cart (A51691)
2013 Yamaha YDREx4...
2025 IR UNUSED Hydraulic Thumb (A53117)
2025 IR UNUSED...
LMC LOT IDENTIFIER 238 (A53084)
LMC LOT IDENTIFIER...
2025 Swict 66in Bucket Skid Steer Attachment (A51691)
2025 Swict 66in...
J BAR SD5 5' ROTARY MOWER (A51247)
J BAR SD5 5'...
