Hand mixing cement for a walkway ??
   / Hand mixing cement for a walkway ?? #1
NIXON
West Sunbury ,Pa.
L3130 hst
Okay . I know I can by ready mix . But if I wanted to mix my own , What would be the proper ratios of portland ,aggregate,and sand ? Thanks , John
   / Hand mixing cement for a walkway ?? #2
Just remember this simple rule 3-2-1. 3 Scoops rock, 2 scoops sand, 1 scoop portland cement. If you want to make it stronger mix in more cement.
   / Hand mixing cement for a walkway ?? #3
From a forgotten website:
</font><font color="blue" class="small">( Choosing a mix
Different applications require different strengths of concrete. Concrete strength is adjusted by varying the proportions of cement, sand and coarse aggregate.
Water-retaining structures, heavy-duty floors and precast items: a mix of 1 part cement, 2 parts sand and 3 parts coarse aggregate or gravel (1:2:3)
Paths, driveways and patios, and garage and shed floors: a mix of 1 part cement, 2 parts sand and 4 parts coarse aggregate /gravel (1:2:4)
Fence post installation and for filling large holes: a 1:3:6 mix
Everyday tasks you only really need to remember the 1:2:4 mix. This mix can be substituted for the 1:3:6 mix. It is slightly stronger but is not quite as economical.
NOTES
All mixes are measured by volume.
Add only just enough water to give the mix adequate workability; adding excessive amounts of water reduces the strength. The amount of water required will vary to an extent, depending on the moisture content of the sand. Sand that has recently been in the rain holds a large amount of water, so the total amount of added water may need to be reduced.)</font>
Thanks for the responses ! I do have one additional question .
I'd like to do an exposed aggregate walk . Any ideas on how to do it ?? John
   / Hand mixing cement for a walkway ?? #5
</font><font color="blue" class="small">( I'd like to do an exposed aggregate walk . Any ideas on how to do it ?? )</font>
I've never done that, but this site is just one of several you can find at google.com with instructions.
   / Hand mixing cement for a walkway ?? #6
I've seen it done one time, and Man, was I impressed with how it looked when it was done. It was done around the pool I was working on. I'm not sure it's something I'd attempt. I will however, pour walks and such myself.
Bird , Thanks for the site info !
Inspector , I'll do it on a small scale to see how it goes , before I attempt a full scale walkway . John
   / Hand mixing cement for a walkway ?? #8
"I'd like to do an exposed aggregate walk . Any ideas on how to do it ?? "
I haven't done it myself, but I watched them put in my front walk and garage apron. They used an aggregate mix rather than seeding the surface, and for a retarder, sprayed on a sugar solution! Yep, a 5 lb. bag of sugar in an ordinary 2-3 gallon, pump-type garden sprayer with wand. To expose the aggregate, one guy stayed behind, waited until the right time, and pressure-washed off the top skin. Looked easy, but I imagine that if you pressure wash too early you'll dig and if too late, you don't expose the aggregate very well or consistently.
   / Hand mixing cement for a walkway ?? #9
I've done it a few times and all I did was wait till the concrete had set a bit then washed the top off with a water hose and a push broom. The first time I did it wasn't intentional, we were placing concrete for a walk and it started raining. The rain kept washing off the surface, so we just let it, and went back a few hours later and finished the job. The people liked it so much they wanted us to do it again. The best looking one I ever saw was done using Mexican beach pebbles (black flat shiny stone). They poured the walk then made up some cement without aggregate, placed a layer of the stone on top of the freshly placed concrete then filled between the stones with the sand/cement mixture and let it set.
Yankee and David J
Thanks for the posts . All I can do is give it a tryAnd see what happens . John
2008 Volkswagen Passat Sedan (A51694)
2008 Volkswagen...
CAT 336 D, Cab, Heat/Air Excavator (A52384)
CAT 336 D, Cab...
2008 Ford F-250 (A53473)
2008 Ford F-250...
2018 Infiniti QX60 SUV (A51694)
2018 Infiniti QX60...
American LaFrance Thermoplastic Striping Truck (A52377)
American LaFrance...
2017 John Deere Z970R (A50123)
2017 John Deere...
