Dadnatron
Veteran Member
I need a 叢ower source for a project I am working on.
I believe a long legible shaft attached to a higher HP/torque motor would work. But, the ones available which I suspect would work are Suhner motors costing from $1K and up. Since I知 not sure my project will ultimately 層ork as intended? I知 not willing to go that route at this moment. Should it turn out and be a reasonable solution to my needs, I壇 have no problem doing so.
I知 not sure of my exact 喪equirements therefore coming up with a HP requirement is beyond my current knowledge. What I do believe is that I need a higher torque, lower RPM MOTOR. I壇 prefer the shaft to be 疎s long as possible but at least about 5 at a minimum.
I have no experience in higher powered machines. I have a small 1/3hp flex shaft hanging machine I use for small cutting and grinding. This is not anything like I would need.
I thought about the shafts which attach to a grinder, but again know nothing about them.
If you have any experience with this type of thing, I壇 appreciate any direction. I知 really trying to gain some direction to at least try something so I can determine whether my direction needs to be altered. I suspect I壇 need at least 1hp perhaps more. Just a guess, but a reasonable starting point.
