RobertN
Super Member
The cross pin for the handcrank on the Farmall came loose, and fell into a black hole! So, I made a new one...
After asking over on ytmag.com, I found the proper length to be 1.5". I measured the cross-hole in the crank, and found it to be 0.375".
I took a piece of 0.5" stock, and chucked it up in the lathe. I turned it down to 0.385"; a bit oversize so it would have a tight fit, and hopefully never come out again. While on the lathe, I used a flat file to put a 45 degree chamfer on the end of the stock, so it would start easy into the hole in the crank.
After using a parting tool to cut the piece to 1.5", I chucked the piece up, and chamfered the other end also. Once done there, I used a press to fit the new cross-pin in the crank.
Presto, like new! /w3tcompact/icons/smile.gif
RobertN in Shingle Springs Calif
