CliffordK
Veteran Member
- Joined
- Mar 8, 2013
- Messages
- 2,358
- Location
- Eugene, Oregon
- Tractor
- Toro D200, Ford 1715, International 884,
For tractors, I think the "new" Landini Trekker 60F will get dedicated to brush duty.How big are the branches that you want to cut up? How much HP do you have? How much land are you wanting to maintain?
Landini Trekker 60F
I picked up a Landini Trekker 60F at auction last week. Data Plate lists 1TAL/AS, but it seems to match the Trekker 60 or 60F. Listed as a Non-Op. If it runs, the price will be an absolute steal. If not, an expensive boat anchor, although the engine may be worth more than I paid, if it...
It is just under 60 HP. I'm still working on it, but it can be started, it runs, drives, and turns. PTO appears to be reversible 540/1000.
As far as branches, most branches larger than 3" or so will get cut into firewood... unless one gets overwhelmed. But that will leave quite a bit in the 1" to 3" size. As well as just some general mulching under the trees.
Acreage? Not a lot. Mom has about 5 acres in oak that will on occasion drop a bunch of limbs. She also has about 5 acres in a scrubby pear (apparently wild rootstock) that may also be wetlands. And a few other patches.
I have about an acre or two in pretty large fir that will occasionally drop large numbers of branches. And it just needs to be mowed under them. I also have an acre or so of small scrubby maple that needs some maintenance. And another acre of blackberries that could go. The blackberries are too steep to be comfortable.
That Landini will be good for hills up to some extent, but I will have to evaluate if it will go into the steep areas with the blackberries.
Anyway, much of this is long term maintenance duty.
As far as clearing, about 30 years ago my parents had about 7 acres cleared by dozer. A lot of work with the burning and making the field. But it ultimately became a nice hay field. A few years later they had the other back 5 acres mulched, but then allowed it to all grow back so it is just as wild as it was before the mulching. Thus mulching to take down trees just isn't a one and done solution.
