Had my first regen today
/ Had my first regen today #21
That is totally opposite of my brother-in-law with his old 1486 International that I can keep track of even when he is over a hill in the field we were chopping by the stream of black smoke. His tractor is rated at 145 PTO HP, my M135GX is rated at 110 PTO Hp, yet I out chop him by a 4 to 3 margin. I don't know if his tractor is that down on power due to old age. Choppers are same model and condition. It has been interesting to see how this tractor will do against his.
Was the 1486 tested at Nebraska?
/ Had my first regen today #23
Yes, the HP rating is from the Nebraska Test Report. The Kubota M135GX has not been tested at Nebraska but its predecessor, the M135, did have a Nebraska test and came in at 12 PTO HP greater than advertised. Not sure if that is significant as the new GX has a completely different fuel system although on the same block.
/ Had my first regen today #24
I found the nebraska test for the 1486. It is 145 PTO HP. Something is wrong if a 110-120 PTO HP tractor will out work a 145hp tractor 4 to 3.This is a example of why I think the Nebraska test is useless.
/ Had my first regen today #25
Ya think a few ponies could have escaped? It's 30 some odd years old.
/ Had my first regen today #26
Tier II was the limit of emission regs that made any sense and were practical.
The Green Weenies in the EPA are ticked off that manufactures were able to meet the Tier IV specs. Soon Tier V and CO2 regs will have to be introduced to try and eliminate the internal combustion engine from fields and highways.
/ Had my first regen today #27
seems insane to me that now we get to pay for this of tractors, i remember when this dpf issue came up with ford and chevy, i remember reading about a ford melting the asphalt it was sitting on, im sure it was just one of those crazy stories that come up between the ford vs chevy guys. back in 97 gm had a 6.5 S, this was a 6.5 diesel with a sort of egr and a cat converter, those were the nastiest of all 6.5's to work on.
/ Had my first regen today #28
A few maybe but not enough to get out worked by 25% by a tractor that is 25hp less.
/ Had my first regen today #29
http://youtu.be/-dKLKm5i2ic
This is probably what you read about. If I remember correctly they suspended sales for a while over this???? Or not??
/ Had my first regen today #30
I have a few other ideas as to why/how its possible, but with out putting each on the same dyno we'll never know.
/ Had my first regen today #31
Part of it could be an old gear transmission vs. power shift. He has to go the speed of the heaviest part of the windrow where I can shift up and Dow - actually auto downshift when the tractor pulls down to the engine speed I have it set for and upshift when the power meter drops below 80%. I have MFWD vs his 2WD - a major advantage in soft fields, especially as the chopper boxes fill. The 1486 could be down on power due to age and hours but it did have a rebuild so I believe it has less than 2,000 hours since overhaul. Lack of gearing, lack of 4wd, and lack of instrumentation (I can see what power level I am at and don't have to guess) all improve efficiency.
/ Had my first regen today #32
There are a lot of variables when chopping. One farmer I worked for had two similar Deere tractors, one with power shift one without. These were the same model and similar year and hours. The one without the power shift was about 10-15 HP more at the drawbar because of the transmission mainly. Yet it also weighed at least a 1000lbs more and could only shift between high and low basically where the other could shift anytime. I found the power shift tractor at least 20% faster because I could shift up a gear or two on headlands or down hills where the other you could not very easy. I could also on an uphill start out in a higher gear and if needed down shift as the load filled. I could also shuttle to a wagon change faster. The condition of the knives and setting of the shear bar make a huge difference in power used to cut. These tractors were used on the same chopper, it just depended on which one was free.
The one without the power shift could pull a plow a little faster, but that was the only advantage it had. The power shift tractor could make up some difference in muddy or uneven ground again by shifting on the fly.
In another post you said he's blowing black smoke, which some it probably will. If it's blowing a lot though I would think he might have a air cleaner issue.
/ Had my first regen today #33
My first regen today at 31 hours was a non event. Didn't know anything was happening except for the yellow regen light being lit and the DPF indicator blinking 100% and 0%. This happened at a time when due to field conditions I was running extremely low load - it took 15 minutes. The book doesn't give an indication how long a regen will take. I chopped 12 loads vs. my brother in laws 7. Power shift and 4wd sure make up for lower power. I may yet learn I depend on Kubota's auto shift too much because I run much closer to peak power than I would without it knowing the tractor will shift down when it thinks it needs to.
/ Had my first regen today #34
Evidently the tractor's computer didn't think you were at extremely low load and was able to Regen without any power adjustments. I'm assuming you were at PTO speed?? Curious to see what it does when it goes into Regen mode while doing piddly idling work. Keep us posted.
/ Had my first regen today #35
Good to hear the tractor is working out well.
/ Had my first regen today #36
All the regen is supposed to do is to add fuel into the system to bring the DPF up to the required temp to burn out the soot. If you are working harder it will need less added fuel to bring it up to regen temperature. My operating at light load would therefore have cost me extra fuel and according to the book required a longer regen time. I was concerned about the engine speed limitation during regen (the computer will not let the engine run at low speed during regen) but I found it would let me reduce to low idle for re-engaging the PTO
So far I am pleased with fuel consumption, very pleased with lack of soot (I don't miss the diesel smoke odor at all), and surprised at the power. I still worry about having a regen at the end of the day and having to sit for 15 minutes while the regen is completed. The operator manual doesn't address that.
With the cleaner exhaust I wish I could afford to trade my L5740 for a L6060 based on the performance of this tractor. My L5740 sits in our heated garage during the winter and gets used nearly every day. It sometimes sets off the smoke detector in the garage on start-up due to the dirty exhaust and the garage is too smelly to work in until the air exchanger cleans the air.
/ Had my first regen today #37
Sounds like you prefer the new DPF engines which is good to hear from an actual owner of one.
/ Had my first regen today #38
I am surprised about the soot with Tier IV. You assume they are cleaner because that's the goal but how much cleaner is what surprised me. Our Grader is two years old and the inside of the exhaust pipe is totally clean. You can wipe your finger in it and not get dirty.
I haven't experienced a Regen at the end of use yet. I'm curious if the machine will allow itself to be shut down or not.
/ Had my first regen today #39
A company doing business with ours has a fleet of 3 year old Mack tri-axles. Don't know which engines they have, but they all have def tanks. The inside of their exhaust stacks are pefectly clean as well. I've never seen anything like it. Looks like the day it was made - just bare, clean metal. And if you all remember just a few years back, a Mack was the truck that ALWAYS smoked under load.
/ Had my first regen today #40
It is impressive how clean the exhaust is. My dad has an 08 3/4 ton truck with a diesel and the emissions equipment, he has about 65,000 miles and the inside of the tailpipe is clean. I have an 07 3/4 ton diesel without the emissions equip and there is thick soot in my tailpipe.
(2) 330 GALLON POLY TOTES W/CAGES (A60432)
(2) 330 GALLON...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
2020 INTERNATIONAL LT625 SLEEPER TRUCK (A59905)
2020 INTERNATIONAL...
2019 American Signal T465 Towable Solar Message Board (A59228)
2019 American...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
