Hackberry is one of the worst to much!
   / Hackberry is one of the worst to much! #1
Texas jerry
Cat 272c with tush Hogg mulcher and many other attachments. 50 hp tractor with shredder.
I posted a couple of weeks ago about new mulcher heads. I went ahead and purchased the fecon 7460. So far I have been happy. One of the first jobs I did with it was a fence line with a lot of standing dead and alive hackberry. The fecon preformed well, i will definently be buying a mulcher door bc the fecon throws mulched material ALOT further than my tush Hogg head. Anyhow I just completed another job that consisted of multiple large bull dozed piles primerly all hackberry. I grappled the piles apart then mulched. I must have gotten the fecon head jammed half a dozen times, once I had to cut the limb out with chainsaw. I have noticed shorter hackberry logs less than @ 4' with enter the mulch head and bind it down. It happens more frequent on the fecon vs tush Hogg due to how much Clarence is between mulcher drum and shroud. I use a carbide tooth which causes the tooth to almost bounce rather than mulch. I have done numerous hackberry jobs and have came to the conclusion heckberry trees are the devil.
   / Hackberry is one of the worst to much! #2
The easiest way of clearing a jammed head is to put it on the ground or a log,turn the mulcher off and drive backwards. If it is more server than that I rap a chain around the rotor so that it will rotate backwards,hook the other end onto something solid then quitely drive the machine backwards. I have cleared wire rope, fence wire, thick vines and big chuncks of timber using this method,no worries.
Just a tip:thumbsup:
I have done that method of turning hydraulics to high flow off and dragging mulcher wheel on ground or exen on tree or stump to free jam. I have heard of wrapping chain but have not actually done it. I will defiantly need to try it next time. Thanks for the heads up.
   / Hackberry is one of the worst to much! #4
Totally agree. I bucked up and split some hackberry mixed in with other trees i was clearing after ice storm damage once. Now, it can rot where it lays, far as I'm concerned.
   / Hackberry is one of the worst to much! #5
OH, but it steam bends so good.
But I'll never cut it with my band saw again. Bout never got all the sticky juice residue off the blade and tires.
Ha ha I was thinking the same thing. Leave it to rot, but I finally finished after a lot of grief.
Do you make furniture out of the hackberry?
   / Hackberry is one of the worst to much! #7
No, I'm not a furniture maker although I've made some pieces over the years like a gun cabinet, small tables, and head boards etc.
That pictured was a test piece (first attempt at bending) from a tree in a fence line that needed to be removed. I do have two forms built to bend old high chair arms for a restore as soon as I cut down the elm tree. I'd rather have white oak but I don't have that available.
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
100' Roll of new 5/8"/16mm Crane Cable  (A52384)
100' Roll of new...
2016 Chrysler 300s Sedan (A51694)
2016 Chrysler 300s...
Ryno Worx Sealant Applicator and sealant pots (A52384)
Ryno Worx Sealant...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
