Quick Hitches H F 3 point quick hitch
   / H F 3 point quick hitch #1
varmint
Elite Member
Northern Maryland
Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
I noticed in the Harbor Freight sale flyer that came yesterday that they have their 3 point quick hitch (item 93691) on sale for 69.99. They say it's good for up to 45 hp tractors with cat. 1 hitches. It's cheap enough to try, if you want to experiment without spending much. I'd be interested in hearing how they can be used, though the extra weight might be an issue on small CUTs?
   / H F 3 point quick hitch #2
Mornin Varmint,
Harbor Freight at times has some descent stuff for sale that wont break the very first time you use it and thay have some junk also :( For $69.95 you wouldnt think you could get hurt too bad but Im sure it probablly doesnt stack up to Pats Quick hitch either. Honestly thats all pure conjecture on my part since I own neither ! But when you look at the difference in the price, Im sure your getting something with better quality components in the more expensive unit !
   / H F 3 point quick hitch #4
have had one since they first came out. no problems on fitting implements. doesn't weigh much. exteremly sweet for hooking things up. if it broke today i'd go buy another today.
   / H F 3 point quick hitch #5
Mine arrived by FEDEX this morning. Way too cold to go out play with it.
But, as others have said on the other threads, it isn't wide enough. It is 26-1/2 inches wide inside-to-inside. The attachement points on my KK 6-foot rear blade, my KK 5-foot box blade, and my PHD are all 28-1/2 inches wide. My Howse brush mower is 27-1/2 inches wide.
It sure looks reasonably well built -- pretty good for the price. I just hope I can bend it out with a jack like others have done.
Happy tractorin'
Knute
   / H F 3 point quick hitch #6
Happy tractorin'
Knute
What about turning the pins inward?
   / H F 3 point quick hitch #7
I have one and it fits all my implements just fine. It sure is nice to simply back up and lift the bush hog instead of wrestling with it to get it hooked up. I think the newer ones are wider.
   / H F 3 point quick hitch #8
I have one but I also have trouble with my implements. The problem is that there is not standard widths for implement hitches. It wont fit on any of my top links with the implements with the hook that comes with it. You have to get the adapter for that. It will work with my box blade but to use it with my brushhog I would have to adapt the three point hitch on my brushhog. Although I do not have one to me pats quick hitch would be a better option.
   / H F 3 point quick hitch #9
Hi All!
I have one and have used it for 6 or so months. I love it! It works great. :p
There IS a standard for Cat 1 hitches and the newer HFT Quick hitch is right in there. It's the implement makers that choose to totally ignore the standard. :mad:
I have a box blade and a bush hog. The bush hog fits fine but the box blade was too wide. I decided that all of my implements would work with the QH so I modified the box blade to fit.
I have also made a few home made implements so they all fit fine.
For the price it is a must have for me. If it got stolen I'd but another in a heartbeat!
Greg
   / H F 3 point quick hitch #10
gclark94560 said:
Hi All!
Greg
greg most of the ones i have seen have a hook on the top that fits under a llink pin at the top of the three point hitch does yours have that hook and does it work with the implements ?
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
1999 MACK CH613 WATER TRUCK (A50854)
1999 MACK CH613...
IH 1566 Tractor (A50514)
IH 1566 Tractor...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52128)
Michelin CARGOXBIB...
2012 Ford F350 Bucket Truck (A47384)
2012 Ford F350...
2010 Honda accord (A50324)
2010 Honda accord...
