GX345 steering problem ?
/ GX345 steering problem ? #1
Rebs
Niagara Falls, NY
JD 175
I apologize for asking so many questions but I just bought this JD used and want to make sure all is well with it while the dealer is willing to fix anything that is not right.
The steering wheel is a 3 spoke with the John Deere name on one of the spokes. When mowing sometimes the john deere name is on the right side and sometimes it is on the left side as if the steering could be loose with the steering wheel off by half a turn. With the engine not running there appears to be no play or slop in the steering linkage, a slight turn of the steering wheel and the wheels start to move. Would this be normal or not ?
Seems funny to me that when going straight forward the steering wheel could be off by half a turn.
Better explanation. The steering wheel has three spokes, one at the twelve o'clock position,one at the four o'clock position with the name john deere on it, and one at the eight o'clock position. When mowing in a straight line sometimes the spoke with the john deere name on it is in the four o'clock position and at other times it is in the eight o'clock position. This is a variation of three quarters of a turn on the steering wheel. There doesn't appear to be anything loose in the steering linkage. Does this model have electronically controlled steering ? Does the power transfer from one rear wheel to the other during a turn ? Is there a hydraulic steering control valve that could be bad ? This has me stumped. This is my first JD with power steering, my other JD has manual steering.
/ GX345 steering problem ? #3
I would not worry about it, don't think anything is wrong
/ GX345 steering problem ? #5
I can't type well enough to explain it but I really don't think anything is wrong. I sure wouldn't lose sleep over it
Ok Thank you for the replies, I appreciate it.
/ GX345 steering problem ? #7
It is normal. They all do that when they have hydrostatic steering. Turn the wheel all the way to either right or left while the tractor is running, and slowly the wheel will keep on going even though the front wheels are against their stops. You can turn the wheel (stiff to do, but can be done) with the engine off and realign the spokes to where you think they should be, and by the time you are done mowing the next time, they will be off again.
2014 Freightliner Coranado 132 Daycab (A62679)
2014 Freightliner...
1996 International Water Truck with a Caterpillar Engine (A63688)
1996 International...
2000 John Deere 7410 (A64119)
2000 John Deere...
2022 Braxton Creek Freesolo KITCH 18 ft Travel Trailer (A61574)
2022 Braxton Creek...
MINI 30" PALLET FORKS (A64280)
MINI 30" PALLET...
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
