Gurgling noise
   / Gurgling noise #1
Leonard malone
Bronze Member
Kioti ck 25
I've noticed lately that when I shut my tractor down there is a gurgling sound. Any ideas? Thanks, Len
   / Gurgling noise #3
Hydraulic fluid returning to sump and breather is burping
   / Gurgling noise
Is that normal, I never heard it before.
   / Gurgling noise #6
Once yu shut it off, have a good look and see if antifreeze is being pushed back into the overflow bottle.
I had that and it was a head gasket. Exhaust gasses were pressurizing the cooling system.
   / Gurgling noise #7
Hay Dude is probably correct, but another thought is you are running borderline hot or overheating due to low fluid in the radiator.
   / Gurgling noise #8
I also had that happen, and in my case, the problem was simple and cheap.
I had regularly blown compressed air into the radiator to clean out debris, but there was still gunk that wouldn't come out. When the tractor was cool, I sprayed the radiator with a hose to clean it off better, and the problem went away.
For the OP, does this problem only happen for you after heavy use?
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
FRONTIER WR3210 LOT IDENTIFIER 108 (A53084)
FRONTIER WR3210...
5ft 3 Point Hitch Bog Harrow (A51573)
5ft 3 Point Hitch...
2025 INDUSTRIAS AMERICA 227T 7' X 22' HYD TILT TRL (A51247)
2025 INDUSTRIAS...
LMC LOT IDENTIFIER 126 (A53084)
LMC LOT IDENTIFIER...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
