Guestimate of weight of unfilled 15x19.5 R4 wheel and tire?
   / Guestimate of weight of unfilled 15x19.5 R4 wheel and tire? #1
Elakeind
Seymour, IN
2003 NH TC25D
I am planning on removing the right rear wheel and tire of my 2003 NH TC25D to install a remote valve.
The tire is unfilled, and I will remove the two wheel weights before removing the wheel. I am trying to guess the weight so that I know whether this a job that two reasonably fit men can handle, or whether I need to buy/borrow/rent a lift of some sort to make the job safe. The sidewall of the tire is marked 15x19.5 NHS. I can't find a weight for such a wheel and tire combination anywhere online.
Of course, the tractor will be carefully supported on at least two 3-ton axle stands before I fiddle with the wheel.
Thanks for your help!
Jon
   / Guestimate of weight of unfilled 15x19.5 R4 wheel and tire? #2
190 lbs per tire for 6 ply
   / Guestimate of weight of unfilled 15x19.5 R4 wheel and tire? #3
200 for tire, 100 for rim. 300 total, and thats prolly a tad high. 1 person should be able to do it just fine. I can do loaded tires. Just dont let them lay down. Jack the rear up to the perfect height, and one person can walk the tire on and off of the studs. Then lean it up against something.
   / Guestimate of weight of unfilled 15x19.5 R4 wheel and tire? #4
I can't find the chart I used a couple years ago when I filled my big turf tires....
But here is a chart that may help.... I found several charts with a search of "tractor tire liquid capacity"
Or just do the math for your wheel diameter, tire diameter, tire cross section......
Good luck
Rim Guard - Liquid Tire Ballast
Forgot to add...... The chart I used when I did my tires was set up for a 75% total capacity fill.
Thank you all for the quick and very helpful responses! This really is a place to get help.
Jon
   / Guestimate of weight of unfilled 15x19.5 R4 wheel and tire? #6
2023 John Deere 8R 410 Tractor (A53342)
2023 John Deere 8R...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
2022 John Deere 410R Sprayer (A53342)
2022 John Deere...
JOHN DEERE 5083EN LOT NUMBER 136 (A53084)
JOHN DEERE 5083EN...
2023 John Deere 8R 280 MFWD Tractor (A53342)
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A52472)
2006 MACK CV...
