Guess what
/ Guess what #1
KYDan
Platinum Member
Frankfort, KY
Kubota MX5100 HST 4WD
I saw this recently while on vacation and thought it was fascinating. I thought it would be fun to share with everyone as it is a custom modified machine. Some of you may have already seen it and know what it is, but for those that don't it will be a difficult task. At least I think it would be as I would not have or could not have figured it out if I had not seen it where it was located.
/ Guess what #3
I'm guessing some kind of a picker. But, I'm having troubles trying to figure out what one would be picking at a consistant height, maybe 2' or 3' off the ground, and planted in rows.
Perhaps detasseling corn?
But, I think the corn tassels are dropped to the ground rather than being sent to a bin.
Could it be missing a cutting head?
/ Guess what
It does have a cutter, but it is not visible.
/ Guess what
You are pretty close, but that is not what it is used for. A little hint for everyone one is, it is custom fabricated from a harvester and a tobacco sprayer.
/ Guess what #7
I've seen some machines like this used to harvest garpes.
/ Guess what
OK, it is located in the Charleston, S. C. area at the only tea plantation in the U.S. It cuts the top 5-6" from a tea plant. The plant is in the camellia family. It wasn't in operation while we were there, but they were using and old Ford 3000 or perhaps 4000 on what looked like stilts with a rotary 3 point hitch cutter to mow the tops of the plant as they only use new leaves for tea. The next cutting will be with the unique harvester. Innovative bunch.
/ Guess what
It is an interesting process and according to their brochures the only mechanized tea harvesting operation in the world. All of them in Asia utilize massive numbers of laborers.
/ Guess what #11
That's so they only pick the best leaves, right size, color, etc. This results in the highest quality teas. Mechanically harvested tea is used for real low grade teas.
/ Guess what
Not according to these guys, it's just a more efficient method when you don't have $1 a day labor. Most of their process is mechanized and efficient. The tour included their entire process.
/ Guess what #14
Are they selling tea bags or packages of loose tea leaves? Either way, they are not getting the best quality from their tea plants. Asian tea masters tell their pickers what to look for each morning depending on the type of tea they are producing that day. What size, color, etc of leaf to pick. High quality tea is made from hand selected leaves, tea bags made to be plopped in nuked water are from the leaves that don't make the grade for the good stuff.
/ Guess what #15
They have tobacco harvesters now? I must be getting old.:confused:
/ Guess what
? I have no idea, I don't drink tea. I simply was interested in the unique equipment they had fabricated and was sharing it with the forum. The harvester was created from a harvester and a tobacco sprayer, not a tobacco harvester.
Year: 2011 Make: Isuzu Model: NRR Vehicle Type: Truck Mileage: 221,488 Plate: Body Type: Tiltmaster (A61573)
Year: 2011 Make...
SKIDDED PLAIN/WASTE WATER TANK (A63569)
SKIDDED...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
FLAT BED (A63569)
FLAT BED (A63569)
2009 PETERBILT 367 KILL TRUCK (A63569)
2009 PETERBILT 367...
