Guess this attachment....
   / Guess this attachment.... #11
It's one of those thingamajigs that you hook up to your rear PTO that turns an internal drive that does stuff. That was easy.
   / Guess this attachment.... #12
Guess what this attachment is? No hints, and no prizes either, other than you can be the BMOB, if you have the first correct guess. That's big man on the board in case you didn't know. I will say up front it's not a generator or a water pump. And yes, I do know what it is. I'll check back in the morning. Good luck. :thumbsup:
504637d1491370851-guess-attachment-4_roman_chariot_obj_3_1_img-jpg
   / Guess this attachment.... #14
A PTO driven electromagnet used for 'sweeping' a paddock for metal debris...
can also be used for dowsing. :fortuneteller:
   / Guess this attachment.... #16
Even better, i'll show you one in use!
Travis
Dynamometer?
Congrat's to you sir, with the first correct response. You are now the big man on the board, for a day lol. It's actually a M&W PT355 dynamometer. I noticed there were several other correct responses as well, from some other knowledgeable members on the forum. Just thought it would be some fun to do this again.Here's a pic showing the back with all the controls.
   / Guess this attachment.... #19
Do you see the hot and cold water attachments? So that means that it is obviously a clothes washing machine:)
2015 Nissan Altima Sedan (A48082)
2015 Nissan Altima...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
PHENIX TECH HI POT MACHINE (A50854)
PHENIX TECH HI POT...
2025 KG43 UNUSED Chain and Ratchet Binder Set (A50860)
2025 KG43 UNUSED...
3HP Electric Fans (A50854)
3HP Electric Fans...
2014 Ford F-150 Crew Cab Pickup Truck (A48081)
2014 Ford F-150...
