guess my weight
/ guess my weight
I know about cattle break outs. Land I have was fenced over 30 yrs ago cheaply as possibly and patched as needed with loose barb wire. Thanks to some crp cost shares I have mostly new fence now. They required all the stumps left in place though. Which meant no dozer to push. Mulchers couldn't handle the mixture of barb/ field wire and old t posts mixed with vines and trees through the swamp. Brown tree cutters get destroyed by wire also. So the need for owning some custom equipment. If you by chance want to sell some of your equipment please call me at 850-762-8670 or pm me your info. Thanks, Quinton hall
/ guess my weight #12
Wasn't trying to disagree with you on weight. My original guess was 8-10k. Looks like you found more info than I did. 7800-8000 does sound right. Thanks for your time LD1
No problem. I didn't mean to sound confrontational. Just giving you my best guess. Why is it you are wanting to know BTW???
IF it is that important, if you have any truckstops or gravel pits in your area, get it weighed.:thumbsup:
If it isnt that important, and if it were mine, I'd just call it a 8k tractor and be done.
/ guess my weight
8k it is. I like to keep specs on my equipment before I need rather than after. Model, serial, filters, fluids, lift capacity, height, width and even weight sometimes are specs needed when time doesn't allow research. So the weight is for future reference. Such as it may need moved with different trailor in future or some crazy odd issue. Thanks.
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
Tank Only (A59076)
Tank Only (A59076)
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A60352)
2010 International...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2013 Case 850L (A60462)
2013 Case 850L...
JLG 1930ES ELECTRIC SCISSOR LIFT (A59823)
JLG 1930ES...
