Guess I will keep my 1430
   / Guess I will keep my 1430 #11
If you need a pto, the Ventrac is out, the 3 point hitch isn't very strong by tractor standards, and its lift capacity is only a fraction of what a similar hp cat 1 tractor would be.. It sounds like you are trying to operate heavy equipment on slopes that are too steep or uneven.One last thing the Ventrac will climb excellent and hold hills great, but they have very little ground clearance, and get hung up very easily. We have a slightly rutted path in the woods and the Ventrac can't go up it, but a golf cart can.... Keep that in mind if rocks protrude or you have undulating terrain.
   / Guess I will keep my 1430 #12
One nice thing about the PT is that it has a flat bottom and articulates. That helps make up for the low clearance.
   / Guess I will keep my 1430 #13
Yeah. I am pretty impressed with the ability of our PT425 to get over stuff in our woods even with turf tires. I only got hung up one time in 11 years when I crossed over a large log and there was no earth on the other side. I was stuck with the turfs slowly debarking the far side of the slick dead log when trying to reverse out. I think had I had lug tires, I would have gotten back off of that log. Chainsaw made for quick escape. Now that I am using the PT for firewood logging and mowing, I would like to have bigger wheel motors for more torque and less top speed. Heck, I think I would like two PTs! One for high speed and one for mountain goating. :laughing:
   / Guess I will keep my 1430 #14
Plowing on a hillside is challenging. Would rototilling work for you? The PT tiller works great for me, but I don't have a commercial garden.
In this area, lots of farmers have old Cat D1s or D2s that they use for slope plowing. The Cats are really fuel efficient and very simple machines. (I love it that some of the old D1s have a little gas engine, that you pull start, that starts the diesel. No battery needed. Great for sitting on the edge of a field for the rest of the summer and all winter. :)
The tough part around here is getting someone to sell it. :)
All the best,
Peter
ponytug I do use the rototiller but would like to have the option to plow new areas and to use a other PTO implements but for now I will continue to use the 1430. It does a good job and I would not actually let it go.
   / Guess I will keep my 1430 #16
Dear Farm23,
Could you use a ripper first to break up the soil and then rototill?
I remember once seeing a powered implement that had a subsoil drawbar, with a rototiller above it to break up the fractured soil. It was supposed to use a small fraction of the horsepower that moldboard plowing requires. No idea what it is called, but it is common in Europe for smaller holdings.
All the best,
Peter
   / Guess I will keep my 1430 #17
We are in the mountains where level ground is a premium and we grow certified organic produce. I was thinking a tractor with rear PTO would be helpful so a dealer brought what he said was a good tractor for the mountains. He was working one of the fields and the tractor turned over. Fortunately no one was hurt. Guess I will continue to drive back wards.
Have you seen a John Deere 20A? I don't know if JD still has the relationship with Goldini, but these units will handle hills...:)
At 32 in. wide, the 20A Tractor is designed specifically to operate in rows as narrow as 4 ft., performing a variety of tasks including cart transport, sprayers, mowing and ground preparation. Equal-sized wheels, a 39-inch wheelbase and a low center of gravity maximize the tractorr stability.
If you need more horsepower check the F-Series Tractors(Goldinis manufactured for JD)
At home under almond trees, in pear orchards or vineyards, the F-Series Orchard and Vineyard Tractors deliver 76- to 96-engine hp, 4-wheel drive and 4-wheel braking, and open-station or low-profile cab options. With a lift capacity of more than 5,000 lbs., the F-Series can handle heavy rear implements like loaded gondolas and full sprayers, even on steep terrain. Designed and built from the ground up as an orchard and vineyard tractor, the F-Series is made to meet your specialty crop needs.
   / Guess I will keep my 1430 #18
Sounds like a serious tractor!
As a youngster, I remember driving ford tractors in orchards around Wenatchee area, plenty of hills. You got real quick at dropping loads down to the ground to keep the tractor upright.
   / Guess I will keep my 1430 #19
Looks like an antonio. Where would you get one in the US I wonder? I looked very hard at an Antonio as we have a "dealer" about 200 miles away, but the price was so high it made no sense.
   / Guess I will keep my 1430 #20
These are Goldinis that were manufactured for John Deere...so JD would be your support location
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A57453)
2000 Volvo VNL...
2004 Yamaha Golf Cart (A55853)
2004 Yamaha Golf...
Rhino TW84 (A56469)
Rhino TW84 (A56469)
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2019 FREIGHTLINER...
EZ-GO Cart (A55853)
EZ-GO Cart (A55853)
