guard for hydraulic filter on 2210
   / guard for hydraulic filter on 2210 #11
I noticed that on my brother's 2210 and thought "what idiot designed this?" I told him to stay out of the woods with it or he'd be sorry...
   / guard for hydraulic filter on 2210 #12
I must admit, the filter and the hydro cooling fan could cause troubles. I was using my bush hog on a new 4 acre field. Started with the MMM on, but it kind of got in the way. Grass was taller than the hood, and the MMM was acting like a plow. So I decide to remove the MMM. When I got done and was cleaning the grass clipping, I notice the hydro fan was stained green and chipped slightly. The little hydro fan was doing it's own bush hogging with the tall grass. Luckily all the blades are intact.
Plus grass wrapped around filter.
Bob
2210/62C MMM/ 210FEL
because I don't have a MMM I think I'll design a skid plate for it. I will be getting my firewood with this tractor (my 6400 is too bulky)and want it protected. I skidded a couple of trees last night and it worked well, but I sure don't a stick to come up and wreck the filter again. /forums/images/graemlins/frown.gif
   / guard for hydraulic filter on 2210 #14
Wait until you peel the blades off that fan...Then the filter seems like a genuine bargain ! Now that I'm aware of it I'm just more carefull.
   / guard for hydraulic filter on 2210 #15
I went in to JD and bought all the supplies I needed for my 50 hour service on my 2210 and nearly fell over in shock when the guy told me the total! /forums/images/graemlins/shocked.gif
   / guard for hydraulic filter on 2210 #16
megotractor,
Just curious, what did your toppling act cost?
Coming up on 50 hrs. /forums/images/graemlins/confused.gif
   / guard for hydraulic filter on 2210 #17
50 hour service consists of engine and hydraulic oil changes. I purchased 3 quarts engine oil and filter, and 3 and 1/2 gallons hydraulic fluid and filter; $68.oo /forums/images/graemlins/shocked.gif
well I think I've designed by plate, now I just need to get off my rear and build it. I think if I go 20" I can cover both the filter and the fan. I don't want to go too much more because I think that will keep tooo much heat in the machine.
   / guard for hydraulic filter on 2210 #19
Make sure you post a picture of the guard. Maybe you could make some extra $$$ on e-bay.
Bob
   / guard for hydraulic filter on 2210 #20
JD2210:
I joined the "stick in the cooling fan" club. When my 2305 comes back from the dealer, I'll be wanting to add a skidplate for the fan/filter. Did you finish your design/installation? If so, care to share the details?
Thanks, Wayne
New Holland TN75S 4WD 75HP Loader Utility Tractor (A55787)
New Holland TN75S...
Belarus 250AS Tractor W/Loader (RUNS)(DOES NOT MOVE) (A50775)
Belarus 250AS...
TRANSMISSION JACK (A55745)
TRANSMISSION JACK...
8' SMALL FENCE POSTS (APPROX. 40-50 PC) (A54757)
8' SMALL FENCE...
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
