GTX 2154 LE
   / GTX 2154 LE #1
harleyizy
Bronze Member
Greenfield Center, N.Y.
GTX2154LE
Has anyone else had a problem with their electric power steering? I have a GTX 2154 LE and the power steering went bad. Little over 100 hours. Would not start one day...battery was dead. Charged the battery and blew the driveway. By the time I was done, had no power steering. Battery light came on and would not start. Had the dealer pick it up and after waiting, the whole steering unit was replaced. Apparently, when the unit goes bad it drains the battery. You cannot "jump" start the tractor, even with a booster. You have to charge the battery itself. Of course, the steering unit will continue to drain the battery even with the key shut off. Cub came out with a retro-fit unit that has diodes built in so it will not continue to drain. Unit was replaced under warranty. Just wanted to give everyone a heads up.
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
2018 CATERPILLAR 305E2CR EXCAVATOR (A51242)
2018 CATERPILLAR...
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
2023 BANDIT SG-75 STUMP GRINDER (A51242)
2023 BANDIT SG-75...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A52128)
Quick Attach Skid...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
