Gt6000 add extra fuel tank?
   / Gt6000 add extra fuel tank? #1
DanGt6000
Craftsman gt 6000
Am going to be snow plowing this winter with my gt6000. How can i hook up an extra gas tank? I want to be plowing for a while an not run out of gas. I already have a small tank off old tractor with a hose coming out of it. Can i just cut the current liine a put in a Y adapter or something? I think im going to put it under the hood behind the battery.
PLEASE ANY TIPS APPRECIATED!!!
   / Gt6000 add extra fuel tank? #2
Does it burn that much gas? Yes, any kind of fuel-proof Y valve and approved hose, carefully routed will probably work. Me, I'd be ready for a stretch and a hot cocoa between tanks of fuel.:D
Thanks for reply. R their gas pumps on these? Or do i hav to have the tank higher than th line
   / Gt6000 add extra fuel tank? #4
The GT 5000 has a crankcase vacuum powered pump. I'd make a bracket to hold an extra can.
Hm... so, where do you suggest for me to mount the can? I was thinking to the back, behind the seat. Would it be possible to link the second tank, (which is small), by feeding the hose through the First gas tank lid. I mean by drilling a hole, and snugly fitting the hose through the cap. I figure, if the first tank is empty, I can poor gas into the second tank, and it would fill them both at the same time. And I will just leave that hose in there.
   / Gt6000 add extra fuel tank? #6
Alternatively, you could put the tank where it works best for you and use a "Y" valve.
hmm... so I can just cut the gas line, just about anywhere.. And put a Y valve in there?
Where is a good spot to mount the tank? I mean, is there any place that could potentially be dangerous?
   / Gt6000 add extra fuel tank? #8
I'd be very cautious about connecting two tanks and I cannot give any advice about those connections. I would be more inclined to have a small trailer with shovel, salt and 2 extra gas cans; or some bracket from the rear hitch or on the frame of the snow plow. When I did this sort of thing in the '70's I had a gas can strapped to the frame of the plow (for transport only) and when I'd do a driveway I would take it off. Later I graduated to a trailer with shovel for extra $$$ for the side walks.
Ok. I appreciate all of your guys's replies. I think I will just make a bracket to hold a tank on the back. Zork, you just pull a lawn cart when you plow? do you plow with it attached? or do you remove it before starting?
   / Gt6000 add extra fuel tank? #10
Just removed it before starting. 1) Stop and get the job. 2) take the lawn cart off at a safe place.
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
2020 Mesa Ridge Lite 2802BH 32ft Travel Trailer (A52377)
2020 Mesa Ridge...
2025 Splash 20ft T/A Flatbed Tilt Trailer (A52377)
2025 Splash 20ft...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
