GT48DXLS maintenance questions
   / GT48DXLS maintenance questions #1
plowhog
Elite Member
North. NV, North. CA
Massey 1710 / 1758, Ventrac 4500Y / TD9
Someone said the manual called for a first oil change at 8 hours. I read it now and it says do it every 50. I didn't see a sooner interval for the first one?
The deck washout instructions advise to have water flowing, engine at high rpm, and engage the blades. Yikes. I only engage blades at low rpm, then increase rpm to mow. Is it safe and OK to engage blades at max rpm like the manual calls for?
   / GT48DXLS maintenance questions #3
I've found the washout port to be useless.I always engage the blades at full throttle when mowing.
Thanks. I found it in the Kawasaki manual.
I checked my tires and found they were close to 30psi !!! I let air out so they are each about 10 psi. I think I read somewhere that they overinflate the tires for shipping?
   / GT48DXLS maintenance questions #5
10 is good. Most times the manual will show 14 in front and 10 or 12 in the rear. Keep the 12 with the taller tires only. bagging? Keep the higher inflation. I launch a deck at about 3/4 throttle to lessen the shock on the belt.
I've been engaging the deck at idle. It bogs the engine, but doesn't kill it. So maybe I should add some more rpm?
   / GT48DXLS maintenance questions #7
More RPM - 2/3 - 3/4 Yes.
Tyres over-inflated for shipping - Yes.
Oil change at 8hrs - Yes
Washport and hose. RPM High - Yes.
Tip: With blades running and water 'on' alternately raise & lower deck to create 'swirl' effect using induced air. Better washout.
:wrench:
(4) 12' & 10' Corral Panels (A50515)
(4) 12' & 10'...
2007 Sterling LT8500 Tandem Axle Dump (A47384)
2007 Sterling...
Electric Mobility Scooter (A51694)
Electric Mobility...
Hayrack (A50515)
Hayrack (A50515)
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
